clutch problems (please help!)
Old Sep 21, 2009 | 09:09 PM
sxe1215's Avatar
i have no idea what the problem is so ill be as specific as possible
k so today i drove my 04 8 (exedy clutch if it matters) to school and it drove fine like normal. i have a 15mins class break so i went and sat in my car with some a/c on (of course it was sitting in neutral). After my next class i hopped in to go home and the clutch felt very light and i couldnt get it in gear without pushing rediculously hard. finally i got it in gear and made it home, but when ever i came to a stop and came out of gear i couldnt get it back into 1st or even 2nd for the life of me, and also even though the clutch was all the way in the car still pulled forward. I got home and did some reasearch and went to try to start it and when i pushed in the clutch it went completely in with complete ease and wont come back up unless i manually pull it.
Tow truck is comming tommorow and im worried about a trans. shop trying to get me to buy a whole new clutch when it could be something much smaller.
Anyone with the same expirence or ideas/solutions?
thanks in advanced!
Old Sep 21, 2009 | 09:11 PM
Jon316G's Avatar
Grasshopper
Bleed your clutch.
Probably air in the line.
Old Sep 21, 2009 | 09:12 PM
xun4gvn4everx's Avatar
True love is blue x2
ANd your clutch bracket is intact and fine?
Old Sep 21, 2009 | 11:05 PM
newguy's Avatar
zoom fuckin zoom
Originally Posted by Jon316G
Bleed your clutch.
Or you gotta leak and no clutch fluid, check the resevoir for fluid. Youll need to bleed the clutch as stated^^ after you fix the leak and refill the fluid, if you have a leak.
Old Sep 21, 2009 | 11:16 PM
-SiNStaR-'s Avatar
ive had the same exact problem and i have a exedy clutch too.
Old Sep 21, 2009 | 11:17 PM
okay.....and what was your solution?
Old Sep 21, 2009 | 11:24 PM
-SiNStaR-'s Avatar
i had it looked at by the dealer and a few local shops i trust and nobody could figure it out ... never had any fluid leaks or anything mazda dealer said it could possibly be the slave cylinder going out how many miles do you have on your clutch do you have the exedy stage 1 ?
Old Sep 21, 2009 | 11:26 PM
So you still have the problem? Cause you didn't give a definitive diagnosis in your post
Old Sep 21, 2009 | 11:54 PM
-SiNStaR-'s Avatar
no problems since
Old Sep 22, 2009 | 12:41 AM
DarkLord7854's Avatar
Software Engineer
Since what? What'd you end up doing?
Old Sep 22, 2009 | 12:46 AM
^+1 Thats what I was asking sinstar.
Old Sep 22, 2009 | 07:33 AM
sxe1215's Avatar
i checked the fluid and its full, and yes its a stage 1. unfortunately it already got towed to a shop and im crossing my fingers the show is gonna be honest with me
Old Sep 22, 2009 | 08:10 AM
Frosty288's Avatar
n0 pants
Nah, I JUST went through this. Pedal would fall to the floor, and would only actuate nearly all the way in. The only way to get it to return to normal position was to pull it up with my foot.
Turned out my clutch bracket had been shot. Inspect your bracket, and then reinforce or replace the assembly. Also when I did reinforce my bracket I had to adjust my clutch pedal as well.
Old Sep 22, 2009 | 08:37 AM
ferg's Avatar
this clutch always gets shot on this car because if you drive hard your in high rev.. BAM!!!! or SNAP!! lol even maybe CRACK!!! lol
Old Sep 22, 2009 | 10:16 AM
RotaryResurrection's Avatar
kevin@rotaryresurrection
Slave or master has failed, or the line has gotten air in it or leaked out fluid.
Old Sep 22, 2009 | 11:03 AM
DRFTGTO's Avatar
My cavalier and my neon..
Hmm it might be the clutch bracket but when my friends went out he couldn't get it into gear period
Old Sep 22, 2009 | 11:06 AM
sxe1215's Avatar
alot of talk about clutch bracket, is that a releativly cheap fix?
Old Sep 22, 2009 | 11:40 AM
You can try and reinforce weld it yourself, or you can just order the barcket reinforcement kit.
Old Sep 22, 2009 | 01:21 PM
Frosty288's Avatar
n0 pants
I've heard it both ways. When mine went, I could still get it into gear, it was just extremely hard. It was actually a bit hard to get it into gear before it failed, too.
To buy the bracket it's 108.87 shipped. I'd go for the welding too, and it's probably a good way to go, but to me that doesn't fix the initial problem that the metal is still too thin. This means it will still flex, I had the bracket in my hand and was bending it with my fingers, it feels like a heavy duty soda can.
Old Sep 22, 2009 | 01:23 PM
ferg's Avatar
can we get some photos please
Old Sep 22, 2009 | 01:33 PM
Huey52's Avatar
Registered Zoom Zoomer
Thankfully with the brace tho' it won't adversely flex at the historical spot weld points of failure.
Old Sep 22, 2009 | 01:41 PM
This should answer any questions:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-clutch-pedal-bracket-removal-fix-170387/
The aftermarket bracket is from Fluid Motorsports if you decide to go that way.
Old Sep 22, 2009 | 01:43 PM
Race Roots's Avatar
Former Sponsor
https://www.rx8club.com/showthread.php?t=170387
Changed names
http://raceroots.com/index.php/produ...cessories.html
Old Sep 22, 2009 | 01:44 PM
ah ok, I was wondering about that. I kept looking through the pages trying to figure out where "he" went.
Old Sep 22, 2009 | 02:09 PM
kersh4w's Avatar
Hit & Run Magnet
im not happy about the new name.
