Catalytic convertor died..
Old Sep 20, 2009 | 08:00 PM
aa@uow's Avatar
AU Catalytic convertor died..
Hi guys,
My car has been having issue revving above 6500rpm, I first thought the problem was because 1 of the O2 sensors being dead, but one night, after a night cruise at the royal national park, i realised it was not just the O2 sensor casuing the problem...
the entire CAT & sensor glowed !!
any 'cost-efficient' solutions that you can please recommend me??
Thank you very much.
Old Sep 20, 2009 | 08:01 PM
dondo's Avatar
100% baller (finally!)
warranty?
Old Sep 20, 2009 | 08:09 PM
aa@uow's Avatar
warranty is gone already..
Old Sep 20, 2009 | 08:11 PM
dondo's Avatar
well then the most cost efficient thing to do is punch out the inside of the cat and run it that way. that'll solve your problem and doesn't cost anything
Old Sep 20, 2009 | 09:32 PM
Tim Tam's Avatar
True, but it is very hard to get out!
Custom cats can be made by a half decent exhaust shop for around $800 or so. Beats paying Mazda $2500 for a new one.
Old Sep 20, 2009 | 09:47 PM
laythor's Avatar
I zoom therefore I am.
nothing is too hard with a long screwdriver and a BFH (Big F****** Hammer)
Old Sep 20, 2009 | 09:56 PM
alnielsen's Avatar
Australia is the home of some 100 cel/inch high flow cats. You may want to consider this option.
Old Sep 21, 2009 | 08:24 AM
aa@uow's Avatar
i dont know much about these stuff, can u please give more details?
Old Sep 21, 2009 | 08:49 AM
alnielsen's Avatar
I don't have much in the way of info. I was using Google to search for 100 c/i cat in the US and found several references to Australia. Only one in the US. These would be the cat only. You would have to get a midpipe and cut a slot for the cat to be installed.
Old Sep 21, 2009 | 04:00 PM
rotarenvy's Avatar
http://www.metalcat.com.au/
no experience with them
Old Sep 21, 2009 | 10:05 PM
aa@uow's Avatar
thank you all for the advice and info!
Old Sep 24, 2009 | 04:09 AM
Greenvy's Avatar
I had the same problem with my '03, Substrate collapsed.
Punchin out the the guts of a cat would be illegal in Aus, so i had a temp put in and repalcement O2 sensor.
Use it as a good excuse to significant others for a mod. I was planning on going for this later myself when I have spare money.
http://www.smb.net.au/fullexhaustsystems-mazdarx8.htm
Old Nov 8, 2009 | 07:24 AM
Noddi_76's Avatar
i had the same problem with mine, couldnt rev past 6500rpm for a while, just drove it hard for a little while until the cat. had totally burnt itself out and now i get same power as before and full revs (upto the 10,000rpm limiter). just keep driving it upto the max revs it'll let you until it clears itself. or you could go pay alot of money for a new one, or you could try fixing it yourself.
good luck
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
PTQLam
May 23, 2016 11:17 AM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
