Ararm system gone NUTS!
Old Sep 17, 2009 | 06:02 PM
Spin9k's Avatar
Momentum Keeps Me Going
I had a really truly strange thing happen today. I stopped, turned off the car and the alarm went off - horns beeping, flashers going. I though I must have hit the keyfob button. I pressed the red button it went off.
Then it happened again. And again. I though I must be going nuts! But it stopped.
So went into a store, came back out, put the key in the ignition and started the car. Immediately the alarm goes off. With the car running the red button won't shut the alarm off. I'm freaking out, so I drive away horn blasting, flashers going. Can't stand it stop a short distance away and pull the horn fuse. OK some relief, the lights are flashing, but no sound....I can deal with that.
So I drive a couple miles, and it all stops. Everthing is normal again...until I get home in my driveway, turn the car off...the lights start flashing again! WTF!
Has this happened to anyone. Only thing I can think of is the keyfob is $ucked?
Have an appointment tomorrow w/the dealer, but would rather save the money I know they'll charge. They already said they'd never heard of such a thing, so they'll spend hours doing stuff that will simply waste my $$$.
Anyone?
Old Sep 17, 2009 | 10:22 PM
why dont you just take the battery out of your remote and see ?
if your car goes back to normal, its your remote,
if it doesn't, its your car.
cuz you know you can start your car with no battery in the remote.
but after your car has started your alarm shouldn't beep at all, even you press and hold the button on your remote.
so I dunno, it sounds bad.
Old Sep 18, 2009 | 04:50 AM
Spin9k's Avatar
Yea did that, it's the car.
Old Sep 18, 2009 | 08:46 AM
Check the wires to the Keyless Module.
Old Sep 18, 2009 | 08:51 AM
StormyWankel's Avatar
EVOLVChicago.org
Engrish funny
Old Sep 18, 2009 | 09:27 AM
DubbsLuvs8s's Avatar
Originally Posted by StormyWankel
Engrish funny
Beat me to it.
Old Sep 18, 2009 | 09:36 AM
thats some great help.
Old Sep 19, 2009 | 03:50 PM
this has happened to me in the last 3 cars I have owned.
If you lock the car and your inside it, then open the door the Alarm goes off.
You have to reset it.
Each car is different.
Try puting the key in the ignition and turn it on. Then open the car door.
I think that's how I rest the RX8. If No do the samething with the car running.
It still has it in memory the car was stolen by NYCAPS.
Still don't work... Try to disconnect the battery for ten minutes. don't forget to pump the brakes to discharge any remaining charge.
Old Sep 19, 2009 | 05:12 PM
Spin9k's Avatar
It has stopped doing it for the time being. I have no idea what I did to get it to stop, if in fact it was anything I did. I just hope it doesn't return, but it wasn't a good omen being weird like that. The dealer said he'd never heard of it, and the lead (good) rotary tech said he'd not either.
Fingers crossed.
Old Jul 7, 2010 | 10:05 PM
Charles Cope's Avatar
Spin9K,
Did you ever figure out your alarm problem? My 2004 started "false alarming" this year. Usually after rain (which Michigan has been getting plenty of!)
Old Jul 7, 2010 | 10:21 PM
DarkBrew's Avatar
Extraordinary Engineering
Anyone?
https://www.rx8club.com/series-i-trouble-shooting-95/panic-alarm-172933/
Sound similar?
Here's the story...
Wanted to let my GF (at the time) drive the car so moved the seat up
Drive to dinner
Come out after dinner and the behavior described above.
Pulled fuses so I could drive it.
Unrelated, I was working on my clutch pedal and moved the seat all the way back and after that work I noticed that the problem went away... WTF??
Plugged the fuses back in and all was good??
I have no explanation.
Old Jul 7, 2010 | 10:28 PM
AJRx892's Avatar
the panic button wont shut it off completely you must unlock the driver side door with an appropriate key or hit the unlock button on your keyfob... ,says the manual, not press the panic button
i had it happen yesterday couldnt turn the car off becuase it wasnt warm and well try that next time itll work
Old Jul 8, 2010 | 05:32 AM
It looks like the best bet is that the shock sensor may be the problem. I hope to attempt to "turn it down" by the weekend and will report back.
https://www.rx8club.com/showthread.p...st+sensitivity
Old Jul 8, 2010 | 06:29 AM
Spin9k's Avatar
Originally Posted by Charles Cope
Spin9K,
nope...it happened those couple times last September... then vanished ... strangest thing, but at least it healed itself
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Jb4ker96
Sep 27, 2015 10:06 PM
RXBae
Sep 14, 2015 03:54 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
