Starter Fried
Old Sep 16, 2009 | 02:12 PM
kingsina420's Avatar
TNC
Exclamation Starter Fried
Alryt i was searching all over the thread and cant find the answer....my starter fried and i ordered another one from autozone so this will be my
second one...can u guyz let me know if something could have short circuited? the car has 54,000 miles changed battery/coil/spark plugs last year
Old Sep 16, 2009 | 02:26 PM
EDZRIDE's Avatar
2005 White GT
Originally Posted by kingsina420
...i tried to start my car but it wouldnt crank everything works like the lights and audio but still wont crank...i kick started and it turned on..
How did you "kick start" it?
Old Sep 16, 2009 | 02:38 PM
StormyWankel's Avatar
EVOLVChicago.org
Think he meant push start...
Old Sep 16, 2009 | 04:39 PM
TNC
yeah push start my bad but that was after the starter fried and the only way to get the car starting
Old Sep 17, 2009 | 05:02 PM
TNC
i realized that something myt be shorting out the starter but can not figure out wat it could be any ideas of wat to do? where to check first to fix the problem?
Old Sep 17, 2009 | 05:04 PM
Jon316G's Avatar
Grasshopper
Why do you think the starter is fried?
Have you taken it apart and tested it?
Have you verified you are getting a constant 12V from the battery to the starter?
Did you verify the starter solenoid is getting energized when the key is turned to 'start'?
Old Sep 17, 2009 | 05:09 PM
DefinitiveDetour's Avatar
I thought my starter fried and took it to the dealer.
Bad Connections.
Old Sep 17, 2009 | 05:12 PM
Jon316G's Avatar
Grasshopper
Bad Connections.
Connection to the battery?
TNC
i have tooken the starter apart and the cable on the starter was fried (this was not my orginial starter) the orginial one also went but not like this one...i checked wit my cobb while my car was on the volt and it was readin 13.9.....and how will i know if the starter solenoid is getting energized???
Old Sep 17, 2009 | 05:14 PM
Jon316G's Avatar
Grasshopper
I see you modified your 1st post...
We just had someone else order one from Autozone and had problems with it.
They told him it was the upgraded starter, but the part number he gave was the original weaker starter.
Do you know how to use a meter?
Old Sep 17, 2009 | 05:17 PM
Jon316G's Avatar
Grasshopper
A fried cable would be outside the starter (connects between the motor and solenoid).
You would have no reason to take the starter apart then.
Old Sep 17, 2009 | 05:20 PM
TNC
yeah cuz it was too long of a story and i dont think no one is goin to sit here and read all about it...and yeah i have a meter i forgot to use it to check ill do tht but ummm...i really hate it to be a circuit tht will cause my second starter to fry
Old Sep 17, 2009 | 05:23 PM
Jon316G's Avatar
Grasshopper
Refer to the pick below.
The connection with the white cover is your constant 12V from the battery (ALWAYS ENERGIZED)
The cable below it connects the solenoid to the motor.
The smaller connection to the left of both of those is the signal voltage when you turn your key to 'start'
This activates the "switch" in the solenoid and allows current to continue to the motor.
Verify all these connections first. It'll help narrow down if the issue is with the starter or the current going to the start.
Old Sep 17, 2009 | 05:28 PM
TNC
yeah the cable on the solenoid to the motor fried on my previous one...i installed this one and its taking a while to crank but sound like its not getting enough juice could possibly be the battery i will deff check....but im still confused on how the wire just fried up
Old Sep 17, 2009 | 05:30 PM
Jon316G's Avatar
Grasshopper
Just curious... when you took your starter apart, did you check everything like the pinion gap, brush length, armature, and commutator?
Old Sep 17, 2009 | 05:34 PM
Jon316G's Avatar
Grasshopper
Did you get the upgraded starter?
The original starters are known to be weak.
And measure the voltage at the battery with your meter.
Should have ~12V with the car off and ~14.4V while its running.
Old Sep 17, 2009 | 05:35 PM
TNC
lol oh i never took the starter apart like that i only took it out of the car...im sorry i got the wrong interpretation but no i never took it apart like that
Old Sep 17, 2009 | 05:37 PM
TNC
imma have to get another meter my current one is broken but cant i check it with the AP?
Old Sep 17, 2009 | 05:38 PM
Jon316G's Avatar
Grasshopper
I trust a meter more... but that's just me.
Call me old fashion!
That would be an easy test to do... verify the AP matches what I measure at the battery.
I might just try that.
Old Sep 17, 2009 | 05:44 PM
TNC
true the cobb showed 12.5 while the car was off wen the car was on it showed 13.9...i would check wit a meter but mine is broken
Old Sep 17, 2009 | 05:50 PM
Jon316G's Avatar
Grasshopper
You'll need a meter anyway to check the voltage at the starter
Check both the constant voltage and the one going to the solenoid from the relay.
Old Sep 17, 2009 | 05:59 PM
TNC
okay and if they are not getting energized that indicates its time to change battery correct? and i still dnt know how my started just fried up could it possibly be because of the battery? btw thnx for all the advice jon
Old Sep 17, 2009 | 06:02 PM
Jon316G's Avatar
Grasshopper
Depends on the connection you are measuring.
Remember, one is coming from the battery and the other is coming from a relay.
Depends on if you measure anything unusual in one of these circuits.
If they appear fine, then its something within your starter.
Also keep in mind if the connection to the batter is loose, it'll cause issues too so it may not be a bad battery.
Old Sep 17, 2009 | 06:09 PM
TNC
all my connections are tightened and i have an optima battery and im goin to put that in there to see wat happens...if not the what should i do to see if its the relay should i switch it wit the head relay?
Old Sep 17, 2009 | 06:13 PM
Jon316G's Avatar
Grasshopper
I think you need to check the connections at the starter instead of blindly going around the car.
This will help point you in the right direction.
And a new battery *may* help out, but won't fix the problem IF its a weak starter.
Here is a video I made while testing this theory with a local:
http://www.vimeo.com/3653485
