View Full Version : Regular Maitenance Needs in one place!!
Race Roots
09-15-2009, 09:14 PM
Here at Race Roots we have all your maintenance needs in one place and as always IN STOCK and READY TO SHIP!
Another Great thing is FREE SHIPPING ON ALL ORDERS over $100!!!
K&N Drop in Filter for $55 (http://raceroots.com/index.php/products/mazda/rx8/intake/kandn-replacement-air-filter.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/33-2284-1.jpg
K&N’s replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. The stock replacement air filters for street vehicles are covered by the famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED.
We have all of your Ignition Needs!!
NGK Iridium Spark Plug set for $80 (http://raceroots.com/index.php/products/mazda/rx8/engine-and-accessories/ngk-mazda-oem-leading-spark-plug.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/normal_1111701743922983laser_platin.jpg
- Laser welded Iridium center electrode tip
- Platinum disc welded to backside of ground electrode provides long life
- Trivalent Metal Plating for superior anti-corrosion and anti-seizing
- Faster starts and quicker acceleration
- Better fuel economy and lower emissions
- Best OEM Iridium spark plug available
- Original Equipment Manufacturer approved design
Laser IridiumŽ spark plugs provide superior ignitability and long service life. Smallest tip diameter available Iridium / Platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions
Car misfiring or hesitating? Poor Gas mileage? Time to get new Ignition Coils!
These are the Mazda OEM Igntiion Coil set
Moroso Spark Plug Wire Set for $90 (http://raceroots.com/index.php/products/mazda/rx8/engine-and-accessories/moroso-spark-plug-wire-set.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/picasa-export.jpg
Features of these 8.65mm wires include a KEVLARŽ core that's four times stronger than Aramid cores, a class-leading 40 ohms of resistance per foot, nickel copper alloy conductors for superior spark energy transfer, an extra-thick EPDM layer for greater dielectric strength, high-temperature silicone boots that can withstand heat up to 600 degrees, and locking stainless steel plug
Each wire set is assembled “in-house” by our technicians using the high quality Moroso ignition components. Each set is assembled and tested to ensure correct resistance prior to final packaging. This custom assembly process provides us with complete control over the entire assembly procedure.
LS* Series Custom Ignition Harness for $160 (http://raceroots.com/index.php/products/mazda/rx8/engine-and-accessories/ls-series-custom-ignition-harness.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/dscf0013_2.jpg
After many requests for an ignition upgrade options we are now offering the RX-8 community plug and play harnesses for MSD or LS2 style coils!
This allows placement anywhere within the engine so relocation can easily be completed and you can create a complete Do-it-Yourself Ignition Solution with the coil pack of your choice!
No cutting, splicing or soldering, just plug into the factory RX-8 harness and plug in the coil YOU would like to use.
Each harness is strain and continuity tested before shipping to ensure years of trouble free performance.
We also have all of your Oil Needs as well including Pre-Mix!!!
Mazda OEM Fliters For $8 (http://raceroots.com/index.php/products/mazda/rx8/engine-and-accessories/mazda-oem-oil-filter.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/prod_oem_oil_filter.jpg
K&N Performance Oil Filters for $12.95 (http://raceroots.com/index.php/products/mazda/rx8/engine-and-accessories/kandn-high-performance-gold-oil-filter.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/hp-1008.jpg
The premium Performance GoldŽ Oil Filter is rapidly becoming a favorite among consumers for its durability and easy removal. The oil filters come with a 1” nut welded to the top of the canister so they can be easily wrenched-off with a standard tool. To satisfy the demands of racers, the oil filter has many features over and above the requirements of most vehicles. K&N oil filters also use a resin impregnated cellulose filter media. This allows for higher flow rates while providing outstanding filtration.
We have all of your Redline Needs! All in stock all ready to go!
Water Wetter for $9.95 (http://raceroots.com/index.php/products/mazda/rx8/fluids/redline-water-wetter.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/234995.jpg
(http://raceroots.com/index.php/products/mazda/rx8/fluids/redline-pre-mix-two-stroke-oil.html)
Premix Two Stroke Oil for $8.95 (http://raceroots.com/index.php/products/mazda/rx8/fluids/redline-pre-mix-two-stroke-oil.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/19_1.png
MT-90 for $13.95 (http://raceroots.com/index.php/products/mazda/rx8/fluids/redline-gear-oil-mt-90.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/mt90.jpg
75W-90 for $13.95 (http://raceroots.com/index.php/products/mazda/rx8/fluids/redline-gear-oil-75w-90.html)
http://i118.photobucket.com/albums/o113/BluMonstrRX8/file_2_20.jpg
9krpmrx8
09-15-2009, 09:22 PM
Can we get the premix in a gallon?
Race Roots
09-15-2009, 09:50 PM
Only the bottle unfortunately :)
I will give discount pricing for those that want a gallons worth
alz0rz
09-15-2009, 10:04 PM
Stock idemitsu damn it
Ross_Dawg
09-19-2009, 02:37 AM
stock idemitsu damn it
+1 ;)
Race Roots
10-03-2009, 11:54 AM
New pricing is now in effect for your regular maintenance needs.
We have lowered pricing on Ignition Coils and Spark plugs and those that stock up save!
http://raceroots.com/index.php/products/mazda/rx8/engine-and-accessories.html
totaleclipse
10-26-2009, 02:05 PM
Order in. let me know when u get update on eta
Race Roots
10-26-2009, 02:13 PM
Already shipped and on its way!
Should have it by Wednesday or Thursday!
totaleclipse
10-29-2009, 03:01 AM
Thank super fast shipping. Wed. morning
Race Roots
03-17-2010, 11:18 AM
Just restocked on more NGK Spark plugs over 40+ sets to go around!
