Slight misfiring?
Old Sep 15, 2009 | 09:08 AM
mat128's Avatar
Slight misfiring?
Hey everyone, I think I have a problem with my coils and/or plugs.
I have already ordered the BHR kit but I would like to know what you guys think.
I made a quick video here:
http://www.youtube.com/watch?v=CEWktRKtK9M
I almost stalled first since I lose so much low end power when the problem occurs.
I had foot on floor (or almost), you can see its very slow. Mind you this is in first gear but its in kmh. You should be able to gauge the slowness only by sound!
Also, the sound of the engine sounds different, more drowned, lower in frequency..
I once had the flashing check engine (calling for some misfires). I shut off the car, waited, checked everything (oil, coolant) and went to smell the exhaust and it seemed fine. Now when I'm getting this problem the check engine aint flashing, but it aint as bad as when it flashed.
The car is an 05 GT with ~40k km on it (~25k miles) and it's bone stock.
I always keep my oil topped. I don't know what was done since I got it at 25k km (~16k miles) and all I did was regular maintenance (oil changes mainly).
The connections from the coils to the plugs seems fine (on the coils side anyway), I tried pushing them in to make sure they were tight. The only problem I can see is on the other side (plug side).
When this problem occurs, I also have hesitation during startup (hard to describe but hesitation that is noticable even to someone who doesnt drive the car daily, ex. my gf).
Thanks in advance,
Mathieu
Old Sep 15, 2009 | 03:25 PM
mat128's Avatar
Bump, can anyone at least confirm that these are misfires?
Old Sep 22, 2009 | 12:58 AM
05rx8mazda's Avatar
B.I.G
yeah bro i would check the coils, plugs, and wires...
then check the CAT.. sea foam the motor.
if all else fails... check compression..
Old Sep 22, 2009 | 12:50 PM
Thumper3322's Avatar
misfire would thro CEL...do plugs and coils and see...still prob check CAT, could be going and causing back pressure...happened to me and eventually completely plugged = new CAT.
Old Sep 23, 2009 | 08:34 AM
mat128's Avatar
The thing is that it's not always doing this. For example in the last 2-3 days it didnt do it...
Is it alot of trouble to remove the cat and put it back to see it's condition or I would need new gaskets and stuff?
I guess I could just take it to the dealer saying I changed plugs and it didnt do anything.
Old Sep 23, 2009 | 01:05 PM
Check your spark plugs. At 25k its time to replace them.
Remove the drivers wheel.
Also, clean the MAF
cliffkemp
Dec 24, 2024 10:48 AM
WranglerFan
Aug 21, 2022 01:29 PM
crimson809
Aug 14, 2016 10:03 PM
XianUnix
Sep 29, 2015 03:48 PM
Forevermore
Sep 20, 2015 01:04 PM
