So my car didn't start. 5 min later it did?
Old Sep 14, 2009 | 03:34 PM
DukeDerox's Avatar
1. So my car didn't start.
2. Radio and air would.
4. Strange buzzing noise.
5. 79XX miles/GT
6. Foggy morning
7. What else would you need to know, lol?
Starts fine and only happened once. Just like to know what happened.
EDIT- I turned the key far enough!! Tried with card key then the actual key.
EDIT2- 2007 MT
Thanks for all the input guys!
Old Sep 14, 2009 | 03:37 PM
kersh4w's Avatar
Hit & Run Magnet
you didnt turn the key far enough.
:P
Old Sep 14, 2009 | 04:41 PM
Smoke Honda's Avatar
Mid-Boss
Was there a lot of smoke?
Old Sep 14, 2009 | 05:02 PM
DarkLord7854's Avatar
Software Engineer
Did it explode? oh wait..
Old Sep 14, 2009 | 05:05 PM
epikeddie's Avatar
It can most likely be from a battery issue or possibly the terminals (which was the culprit in my case).
I had this issue on an extremely hot day - which led to my battery being dead for some reason.
Old Sep 14, 2009 | 05:11 PM
rodjonathan's Avatar
silent assasin
probably a battery issue
Old Sep 14, 2009 | 05:13 PM
Socket7's Avatar
ಠ_ಠ
If the starter motor spun, but didn't engage the flywheel for some reason it could make what could be described as a buzzing noise.
ZumnRx8's Avatar
RX8 & RX7 owner
BAttery
mine did that before in the environment that u stated...
Old Sep 14, 2009 | 05:18 PM
DukeDerox's Avatar
Well it hasn't happened since. I'll give the battery and terminals a once over and clean em to be safe. If the flywheel didn't catch then I would imagine there would be damage that would affect the car in a noticeable way or would possibly happen again.
Old Sep 14, 2009 | 05:31 PM
\\Konig\\'s Avatar
turrrbo!
termites perhaps!
Old Sep 14, 2009 | 06:08 PM
shazy's Avatar
lol.
Old Sep 14, 2009 | 06:18 PM
DukeDerox's Avatar
Originally Posted by \\Konig\\
termites perhaps!
Oh NO, The Renesis Nightmare!!!!
Old Sep 14, 2009 | 06:22 PM
Socket7's Avatar
ಠ_ಠ
I suppose you could have a bad solenoid in the starter motor, keeping it from kicking out and engaging the flywheel, but my money is on a bad battery.
Old Sep 14, 2009 | 07:24 PM
epikeddie's Avatar
Yeah....
My battery terminals didn't even look that corroded or anything. However, they did appear to be tight - but the negative terminal moved ever-so-slightly when pulled on.
After I tightened it down - it has never given me an issue again. Well....until the battery itself was actually no good (later tested to be out of the efficiency range)......then I just replaced with an Optima Red Top with no problems to date.
Old Sep 14, 2009 | 08:29 PM
elysium19's Avatar
Search "clutch switch" on the forums - especially if you have an 04/05, they were prone to breaking. My dealer replaced mine when i had the same problem (my problem was worse though, it wouldnt try to turn over approx 40% of the time).
I'm talkin about the the switch on the clutch pedal that let's the computer know that the clutch is depressed, it's a safety feature.
Old Sep 14, 2009 | 09:01 PM
Myardor's Avatar
car year?
My bet is the battery
and eikeddle? why an Optima Red Top?
Wally world has a much better deal
Maxx 24FS
700cca, 875 Amp at 32degrees F
3 year full warranty, 75 bux
and battery fits in the battery box, no doing anything else, ie that thingy the optima needs cause it a bit short.
Old Sep 14, 2009 | 09:05 PM
Zerotide's Avatar
Snick-Snick Gearbox
Omg haha OP has me in his sig
Old Sep 14, 2009 | 09:10 PM
Myardor's Avatar
That buzzing noise, where did it come from?
Engine bay?
If you cleaned/tighten the battery terminals, then you have fixed the problem. So you will not really know if that was it.
Ya, in back of our minds, we just wonder.
Jesus Martinez
44
May 6, 2025 08:09 AM
delicious_dallan
Jan 17, 2020 09:17 AM
Wantingtoknow
Dec 15, 2016 02:25 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
