Car just died
Old Sep 12, 2009 | 12:04 PM
VS8's Avatar
VS8
4 Cylinder Rotary
Car just died
So I am driving and I was going for my daily redline and missed a shift..it bounced of the rev limited less than a second...I heard a pop and then car just died and turned off. Ignition is brand new...Battery is fine....Fuel pump turns on....Fuses are good
when i was trying to turn on the car it sounded like it was gunna catch but never did
Old Sep 12, 2009 | 01:33 PM
NOTURX8's Avatar
check your ignition coils, spark plugs + wires,
Old Sep 12, 2009 | 01:35 PM
jessedrifter's Avatar
so cal
ouch. ^+1
Old Sep 12, 2009 | 01:39 PM
DeViLbOi's Avatar
The devil made me do it
The pop was the backfire which is pretty common and normal. Who did the ignition install and what was specifically done to the ignition system? Check plug wires on both sides? Verify that it isn't flooded now that you tried to start it with no luck?
VS8's Avatar
VS8
4 Cylinder Rotary
ignition is good...
Old Sep 12, 2009 | 01:40 PM
VS8's Avatar
VS8
4 Cylinder Rotary
i dont think its a small problem like igntion and im catless...and the engine turned off as soon as the pop noise
Old Sep 12, 2009 | 01:57 PM
DeViLbOi's Avatar
The pop was a backfire...no big deal...you should have those all the time being catless. The reason why Im questioning your ignition is because it controls the spark and you aren't getting any. It could be that a coil wire came loose or your ignition has bad timing or it could just be that your eshaft position sensor came off. Hence why it is pretty important to know what you are calling a new "iginition."
Old Sep 12, 2009 | 02:07 PM
Spinning Sushi's Avatar
I <3 Sushi
You guys do know that he's FI'd, right?
OP: Was your car idleing fine after the mis-shift before you turned off the car?
Old Sep 12, 2009 | 02:12 PM
VS8's Avatar
VS8
4 Cylinder Rotary
its not FI yet...was actually planning on starting next saturday
Old Sep 12, 2009 | 02:13 PM
VS8's Avatar
VS8
4 Cylinder Rotary
i didnt turn car off...car turned itself off
Old Sep 12, 2009 | 02:21 PM
Brettus's Avatar
Boosted Kiwi
did the pop noise come from behind you or in front of you ?
Might be a good idea to start with basics .
Do you have spark ?
Do you have fuel getting to combustion chamber ?
Do you have even puffs of pressure from all chambers when you remove one plug at a time ?
Old Sep 12, 2009 | 02:24 PM
VS8's Avatar
VS8
4 Cylinder Rotary
i couldnt tell...
i have spark
i have fuel
my car is just sittin on side of road dont know how i could check
gregs's Avatar
Pull My Finger
sounds like you u need to do the poor mans comression test before moving further
Old Sep 12, 2009 | 02:25 PM
VS8's Avatar
VS8
4 Cylinder Rotary
and that includes?
Old Sep 12, 2009 | 02:29 PM
gregs's Avatar
Pull My Finger
remove the spark plugs and place your finger over the hole, you should be able to feel a pretty strong pulse from the hole while cranking the engine, you will feel little to nothing if compression is too low or nothing at all from each rotor
Old Sep 12, 2009 | 02:32 PM
DeViLbOi's Avatar
How did you check that you had spark on the side of the road?
Old Sep 12, 2009 | 10:20 PM
05rex8's Avatar
sold the 8... :(
+1
how did you verify you had spark..?
Old Sep 15, 2009 | 10:41 AM
gregs's Avatar
Pull My Finger
any updates???
Old Sep 15, 2009 | 11:00 AM
VS8's Avatar
VS8
4 Cylinder Rotary
no not yet...ill be pulling motor this week and seeing whats goin on down there and what i need to rebuild...its been running on low compression for a while
Skyl3r
Dec 2, 2019 04:51 PM
marc2820
Jul 26, 2015 10:47 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
tbiggybig
41
Jul 22, 2015 11:47 PM
