Help!!! Heater and Seat Warmers not Working!
Old Sep 9, 2009 | 11:22 AM
ken5285's Avatar
Guys,
I disconnected the negative battery terminal to reinstall new HID lights and after that the seat warmers and interior heater does not work. Did not touch anything electrical other than the battery and headlights. Would anyone know what has gone wrong with my 05 RX8?
Old Sep 9, 2009 | 06:16 PM
I8U's Avatar
I8U
Electronics 101, would tell you to check all your fuses and then go from there. Besides who uses seat warmers anyways???
Old Sep 9, 2009 | 06:27 PM
Jon316G's Avatar
Grasshopper
+1
There is a 20A fuse labeled "seat warm"
Old Sep 9, 2009 | 11:53 PM
ken5285's Avatar
The heater does not work at all with the **** turned to full heat. Any ideas how to diagnose this?
Old Sep 10, 2009 | 12:29 AM
Jon316G's Avatar
Grasshopper
Did you check your fuses as we mentioned above?
Specifically, check the 7.5A A/C fuse since that energizes both the HEATER relay (for the blower) and the SEAT WARM relay (for the heated seats).
Old Sep 10, 2009 | 12:33 AM
ken5285's Avatar
The thing is the AC blows really cold air but will not blow hot air if the **** is turned to the warm part. I have not had a chance to look at the fuses but which exactly are the ones I should be looking at if the heater and the heated seats are not working at all?
Old Sep 10, 2009 | 12:37 AM
Jon316G's Avatar
Grasshopper
This isn't a difficult thing... check all the fuses!
It'll take you a couple minutes to do.
Old Sep 10, 2009 | 06:29 AM
I8U's Avatar
I8U
wow...
Old Sep 11, 2009 | 11:06 AM
ken5285's Avatar
All the fuses are in good condition. The seat warmers do not work at all, and the heater only works now after I found out that you have to play with the temperature control **** to get it to the right setting by pressing down with pressure while turning to the temperature you want.
Old Sep 11, 2009 | 11:10 AM
Check your HVAC controls ...
there is a DIY showing how to check it ...
Jesus Martinez
44
May 6, 2025 08:09 AM
projectr13b
Mar 1, 2019 09:00 AM
coolcars44
Nov 29, 2017 05:45 PM
mazdaverx7
Jul 21, 2015 07:31 PM
