New Light Making My Idle Rougher?
Old Sep 6, 2009 | 09:07 PM
klanham08's Avatar
Blackin' Out The 8
I have installed a new Interior Light Set, License Plate LED Light, and Side Marker LED Lights on my 8, here are the links:
License Plate:
http://www.rotaryfx.com/product_p/lig1019.htm
Side Markers:
http://www.rotaryfx.com/product_p/lig1028.htm
Interior Light Set:
http://www.rotaryfx.com/product_p/lig1004.htm
Ever since I installed all of these, my idle has been very rough coming to a stop while my lights are on. So common sense makes me think that these lights are for some reason making my idle rougher.
Is actually the reason, or would it be something else?
Old Sep 6, 2009 | 09:47 PM
Jon316G's Avatar
Grasshopper
Only thing remotely close that I can think of is you tapped into the same circuit as the ROOM fuse.
Reason I say this is that pulling the ROOM fuse will reset the ECU, which will cause idle "issues" while the fuel trim is relearning itself.
But even if that is the reason, it shouldn't continue to occur after a couple drive cycles.
Old Sep 6, 2009 | 09:50 PM
klanham08's Avatar
Blackin' Out The 8
I never touched any fuses or anything. Just replaced the stock bulbs...that's it.
ladnarf1
Apr 29, 2021 11:53 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
netrovers
Jul 20, 2015 03:32 AM
