my TPM has been blinking?
Old Sep 3, 2009 | 01:54 AM
Supamang08's Avatar
what does that mean? i know my tires are fully-inflated so i'm not sure whats wrong.
Old Sep 3, 2009 | 03:17 AM
you are sure that the tires are fully inflated to what..
and are you sure that you read the owners manual??? the answer might be in that crazy place..
not really sure what that blinking might be, but i would check the manual first. is it beeping and blinkin?
that is a tough one.
Old Sep 3, 2009 | 05:30 AM
Transam kid 01's Avatar
The anti-ricer
Do you have an aftermarket rim/tire set up? It could be the car not being able to communicate with the TPMS.
Old Sep 3, 2009 | 05:43 AM
Spinning Sushi's Avatar
I <3 Sushi
If I remember correctly, blinking means that one or more TPMS is malfunctioning, not working, or it's not there.
If it stays lit and not blink then that means you have low tire pressure.
Old Sep 3, 2009 | 08:54 AM
rodjonathan's Avatar
silent assasin
^ possible but my aftermarkets dont have the tpms and mine doesnt blink just stays on
Old Sep 3, 2009 | 09:58 AM
Huey52's Avatar
Registered Zoom Zoomer
Although each of our TPMS sensors transmits a signal we only have a single idiot light readout. Therefore, a blinking light indicates one or more of your TPMS sensors is malfunctioning. If you had a steady light then one of your tires has low pressure, or all four of your TPMS sensors are malfunctioning (or in the case of some a/m rims no sensors).
Finding the culprit yourself is problematic but a garage can isolate which signal is not being transmitted.
Heck, even my lowly Jeep Patriot has a 4-wheel independent tire pressure readout, why not the '8?
btw: I just double checked my memory with my Owner's Manual (2005, pg 5-26) and I was correct; a blinking light indicates a TPMS malfunction. Next time you might want to RTFM!
Old Sep 3, 2009 | 12:08 PM
zoom44's Avatar
it means read the quote in my sig. thread closed
Warrior777
Jun 24, 2019 04:47 PM
MANIACman
Nov 11, 2015 10:58 PM
michaelsk8er
Nov 9, 2015 07:06 AM
ShadowDragon78
Aug 21, 2015 03:29 PM
Rx808BI
Aug 9, 2015 10:06 AM
