New Radio HELP!?!?
Old Aug 31, 2009 | 10:38 PM
Semiazas's Avatar
The Dark Carnival
New Radio HELP!?!?
Ok so i was installing a system when my car shorted and fried the Radio board. Now tonight im still working on this i have the new radio installed and hooked up with my old AC controls. BUT my center LCD turns on solid red and the radio does not respond to any buttons on the faceplate. It will take a CD in and i can control the volume and the track by using the steering wheel. the AC controls do not work the only one that works is the fan speed no lights or anything on any buttons. Please help!!
Old Aug 31, 2009 | 11:09 PM
Time to buy a new one. check for sale forum. You were installing a system with the battery connected? Dumb move. Less pot, more thought.
Old Sep 1, 2009 | 12:43 AM
Semiazas's Avatar
The Dark Carnival
? i already replaced it i have the new one here.... And i installed it and those are the symptoms.
Its already 2am here and i just removed the faceplate from the HU again. and i took 1 hour making sure the teeth line up into the faceplate on the driver side of the Faceplate. Tmrw morning i will reinstall it and take a look. If still not working anything else i should look at?
Old Sep 1, 2009 | 12:49 AM
staticlag's Avatar
The Professor
Did you install it when the battery was still connected?
Old Sep 1, 2009 | 12:59 AM
Semiazas's Avatar
The Dark Carnival
No. I am able to give it a CD and it takes it and begins to play it. But i can only control it from the Steering wheel and not the Radio itself. I think its a bad connection between the faceplate and the Actual Headunit itself. tmrw morning ill post pics of the screen
Old Sep 1, 2009 | 01:00 AM
Semiazas's Avatar
The Dark Carnival
static i actually bought the headunit from a place in Omaha called Kosiski or something like that
Old Sep 1, 2009 | 04:05 AM
Nopstnz8's Avatar
I have this same exact problem, but it wasn't a result of shorting my radio. The cause of this is most likely where the screws go in where the faceplate connects to the radio. If these become loose, they will cause your problem. If I press near the location of the screws on the faceplate, bottom left and right, I can get power back on the lcd and control the radio, as well as AC. On mine, the plastic holes where the screws go in broke, so I need a new faceplate to fix this.
Old Sep 1, 2009 | 08:55 AM
Semiazas's Avatar
The Dark Carnival
UPDATE****. I spent 2 hours checking all connections last night and putting the radio and faceplate back together and reinstalling this morning. IT WORKS!!!!
BUT. for some reason the speakers dont get real loud. I havnt had a radio in like 3 months but im pretty sure they got louder that they do now...
nadodave
Aug 28, 2019 05:55 AM
RX8mzda
Oct 1, 2015 10:17 PM
Learners_Permit
Sep 27, 2015 07:38 PM
CMRine04
Sep 23, 2015 09:31 AM
just1jack
Sep 9, 2015 04:45 PM
