any DIY for Pulley set install?
Old Aug 31, 2009 | 07:14 PM
boriqua935's Avatar
NJ any DIY for Pulley set install?
Any here done this themselves??
Old Aug 31, 2009 | 07:16 PM
RX8YA's Avatar
WAH WAH WAH
<-------------- like 3 months ago?
Old Aug 31, 2009 | 07:23 PM
boriqua935's Avatar
any pics or info how to get the crank pulley off?
Old Aug 31, 2009 | 07:29 PM
RX8YA's Avatar
WAH WAH WAH
Ha i had a bit of trouble with that as well. I soaked the 4 bolts in pb blaster after and after i took them out the stock pulley seemed like it was welded on (it wasnt). I took a blogk of wood and placed it on the pulley and tapped it with a rubber mallet. that didnt seem to work but it actually did move the pulley just enough for me to slip a flat head screw driver between and tap the edge with a mallet to pop of the pulley. I had to turn the crank shaft to make sure the pulley came off even because there is basically a sleeve that the pulley slides onto.
UHATEIT
Dec 10, 2015 02:57 PM
bulletproof21
Oct 20, 2015 08:53 PM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
