Need help ASAP
Old Aug 29, 2009 | 11:06 PM
LURCH634's Avatar
Wher'e Going Streaking
Angry Need help ASAP
I put my stock springs back on the front and whenever i hit the brakes it makes a popping sound. please help ASAP. standing by
Old Aug 29, 2009 | 11:13 PM
pineapplesoymilk's Avatar
pure sex
did you take it back apart to see what it could be ? or did you drive it was it poping then you are turning or going over bumps or just when you hit the brakes? or is it like a pulse like the abs kicking in how loud is it?
Old Aug 29, 2009 | 11:16 PM
LURCH634's Avatar
somtimes when i turn, and when i hit the brakes it pull to the right also
Old Aug 29, 2009 | 11:22 PM
pure sex
did you compress the calaper for any reason? and why did you put the stocks back on jw. when you put it back on did you make sure that you tightened every thing control arms if you took them off steering conponents you may want to take it aart again and go really slow looging through everything to just be sure you didnt do something you wernt sopost to
Old Aug 29, 2009 | 11:23 PM
pure sex
is your abs light on?
Old Aug 29, 2009 | 11:26 PM
LURCH634's Avatar
no abs light, tightned everything
Old Aug 29, 2009 | 11:30 PM
LURCH634's Avatar
would how tight the screw is on top of the strut is have anything to do with it?
pure sex
ok well if i were you i would double check and look at the braking system and make sure that a line isnt krimped ir pinched take the tires off and turn the wheel both ways till you hear the poping noise be better with 2 people to do this
Old Aug 29, 2009 | 11:56 PM
LURCH634's Avatar
is there a certain way the strut has to go on? i am wondering if is hitting the control arm
Old Aug 30, 2009 | 12:13 AM
Your End link is loose or its already broken.
check it.
Old Aug 30, 2009 | 12:20 AM
LURCH634's Avatar
thanks everyone. lower contral arm was very very loose.
