short shifter for 09
Old Aug 29, 2009 | 05:44 PM
one2three's Avatar
Just wondering if there is any short shifter will fit 09. Did my search but can't find anything. THX!
Old Aug 29, 2009 | 06:16 PM
mrslysly's Avatar
07 Rx8
THe only available option that I know of for the 04-08 models, is the AFE short shifter. Check out the axialflow engineering website to see if the shifter is compatible.
Old Aug 29, 2009 | 06:26 PM
I8U's Avatar
I8U
Not compatible. But there is one in the works, I believe Paul started working on it from a donor 09 tranny sometime late last year. I'm not sure though.
Old Aug 29, 2009 | 07:27 PM
one2three's Avatar
thx guys. i guess i just have to wait
Old Aug 30, 2009 | 03:54 PM
much2saxy's Avatar
The transmission is the same one they use in the MX-5....I wonder if one of those would fit? It should.
Old Aug 30, 2009 | 05:18 PM
LPCOKIE's Avatar
shifter
this is the only one i could find. other than the one on japanparts .com ,that is $500
http://www.miatamania.com/Shop/ViewP...eIndexID=59694
review
http://forum.miata.net/vb/showthread.php?t=237737
i e mailed axial flow and was told they haven't made a decision yet. i asked for a yes or no if they would make a shifter.
Old Aug 30, 2009 | 11:00 PM
ASH8's Avatar
Super Moderator
Just to clarify an issue here,
The 09 RX-8 Transmission is NOT the exact same one used in the 09 NC MX-5, it is the same design and style, but the RX-8's is BEEFED up a little (some bearings, gears and casing) and has different internal gear ratio's. Input shaft is different, but they share the same identical main shaft.
As far as a short shifter goes, I think the NC one "should" fit, but I can't guarantee this.
I just checked the Genuine Mazda part numbers for the Original Shifter and related parts and they are Different Part numbers, But, this does not necessarily mean an NC MX-5 SS will not fit an FE 09 RX-8.
theblinkof
Oct 4, 2023 05:24 PM
200.mph
Dec 10, 2018 03:49 PM
poacherinthezoo
Aug 3, 2016 11:01 PM
Evan Gray
Nov 24, 2015 01:00 AM
