Slight oil on rear lead and trailing plugs
Old Aug 29, 2009 | 03:47 PM
Paul123a's Avatar
Just changed the plugs and I found some high speed glazing on my front lead plug (which I'd figured is due to my bad driving habits) but..... BUT! I found a slight coating of oil on my rear lead and trailing plugs.... the motor was cold when I changed the plugs ( I pulled it out of the garage, backed up 10 feet, then shut it off.
I figured it was normal (oil sitting in the bottom portion of the rear rotor housing)
Is there an early warning sign for oil o ring failure....
Old Aug 29, 2009 | 04:20 PM
Easy_E1's Avatar
If you just backed the car out and turned it off. Then I would say not to worry. But if you were driving it around for an hour, hmmmm. Could have some weak plug wires and or coils for the rear.
As far as early warning signs for oil control ring failure,, Excessive oil consumption and blue exhaust smoke.
Old Aug 30, 2009 | 08:41 AM
Paul123a's Avatar
Once again you guys (anyone with BHR attached to their post) hit the nail on the head! I had some fatigued plug wires (I replaced them when I changed the plugs...and have some coils on the way too...)
No abnormal oil consumption or blue smoke.
thanks for the reply to my post Easy E-1
05TR1CH
Apr 18, 2023 04:56 AM
Dokuji
Nov 1, 2016 02:51 PM
Sifu
Aug 30, 2015 10:51 PM
eazzyg
Aug 10, 2015 10:32 PM
