Oil pan leak.
Old Aug 28, 2009 | 10:56 PM
mkmike103's Avatar
Oil pan leak.
My car is dripping a small amount of oil. Its coming from the oil pan itself. Thankfully its not dented or anything, but it just looks like its coming from either the side of the pan or one of the bolts holding it up there. Is there an oil pan gasket on there, or do you use some RTV/alternative make your own gasket stuff, or is it just held up there by the bolts themselves?
Any opinions would be great.
Thanks,
Michael
Old Aug 29, 2009 | 12:55 AM
Thanks,
Michael
you need to clean it up and get a photo of were it is coming from.. because sometimes it is not motor oil or it is not from the pan.
first guess is it is stuff spilled from changing the filter. second guess is the tranny. but that is an odd thing that happens..
Old Aug 29, 2009 | 07:12 AM
mkmike103's Avatar
Thanks, will do.
Old Aug 29, 2009 | 10:33 AM
CyberPitz's Avatar
Huge hole is huge
Was the washer reapplied when the oil was changed
Best to see exactly where it is comin' from, then go from there.
Old Aug 29, 2009 | 10:39 AM
mysql101's Avatar
oil travels all over the place, where it drips from doesn't mean it's leaking from that spot. Oil can go from the front of the engine all the way to the rear of it.
I would say wash down the engine, get it clean, let it idle and see where it leaks from.
Old Aug 29, 2009 | 06:40 PM
ASH8's Avatar
Super Moderator
To answer your question, Mazda have not used sump gaskets for over 20 years like most manufacturers....yeah it is BS, give me a gasket any-day..
But yes, there is no gasket, just a silicone type sealer, that is all, and yes you can get leaks there, but as others suggest look for other areas or reasons first.
Old Sep 1, 2009 | 11:44 AM
SilverStreak's Avatar
Agree on cleaning it up first to try to find the exact location. One area you may want to check that a few people noted was prone to leaking is the oil level sensor that runs into the oil pan (look for the wired plug that goes into the pan), there is a small gasket on the sensor that can leak. As I recall in order to replace it you need to drop the pan. If that is the leak, probably easier to clean and try to put some sealant around it to minimize leakage.
Old Sep 14, 2009 | 09:55 PM
mkmike103's Avatar
Heres some pics. not the best I know, wasn't working with a lot of room.
Two of the oil pan bolts are covered, and the wishbone looking thing (technical term, i know) has some oil on it also. When I get under it again I'll clean her up and run it and recheck i suppose. The third pic is to show none of the other bolts appear to have any oil on them.
Figured I'd post some pics in case anyone knew anything for sure about this.
Thanks.
Old Sep 14, 2009 | 10:03 PM
05rex8's Avatar
sold the 8... :(
Looks like the bolts could be loose or you need to make a new gasket for the pan.
First verify if the bolts are loose. If not you will have to drop the pan.
It's pretty easy really to do...just make sure you drain as much oil as you can out of it; the pan is pretty stuck from the rtv sealant and you have to pry it off. But be careful because it is very easy to bend the edges of the pan.
I recommend using this:
It makes a leak proof gasket in 1 minute. It is absolutely the best stuff I've used.
Old Sep 15, 2009 | 06:35 AM
mkmike103's Avatar
Thanks for the recommendation.
Old Oct 1, 2009 | 09:07 PM
mkmike103's Avatar
Figured I would bring this up:
My oil light will pop on from time to time. No problem, pull over and fill it up a bit. Well a day after I did this, the light came back on. I pulled into my driveway and turned the car off and then back on and the light wasn't on anymore, and the oil level seems to be fine.
Is it possible (based on location) my oil sensor is bad, and at the same time causing the leak that is mentioned in this thread?
Just a thought..
Old Oct 1, 2009 | 10:08 PM
05rex8's Avatar
sold the 8... :(
It's possible the sensor is bad...is there oil coming from that location as well?
In the pictures the leak is coming from the side of the drain bolt. The sensor is on the opposite side; not shown in your pics.
Old Oct 2, 2009 | 01:34 PM
mkmike103's Avatar
I wasn't really sure where the sensor was, but I didn't take any pics of the other side only because there was no oil there. Hmm
Old Oct 2, 2009 | 09:23 PM
there was a tsb for the oil sensor in 04.. it does what you are describing..
you are going to have to search for it, as it seems that the quick source for tsbs is gone..
Old Oct 2, 2009 | 09:33 PM
ASH8's Avatar
Super Moderator
Looks like Finish Line have removed their Bulletins...
Old Oct 2, 2009 | 10:27 PM
yes,
and somehow i found it. wonder how long it will be there?
and yes i know where to find them now!!!!
http://www.finishlineperformance.com...13-04-1341.pdf
Old Oct 3, 2009 | 12:41 AM
Lebren's Avatar
RX8club group buy vendor
Swoope=GOD!
Old Oct 3, 2009 | 01:05 AM
Originally Posted by Lebren
Swoope=GOD!
nope,
just pay attention..
but for the greater good!
Old Oct 3, 2009 | 02:24 AM
ASH8's Avatar
Super Moderator
Good on ya Scott swoope...
Do you have a link for the other TSB's, I think it would be good to have a "sticky" here with all of the RX-8 Bulletins, I have about 20 saved....or is there a thread already, should I upload them to a new thread???
What do ya reckon?
Old Oct 3, 2009 | 02:28 AM
ASH8's Avatar
Super Moderator
Found the link from OD's Sticky...
http://www.finishlineperformance.com....php?pageid=11
They should be all uploaded and saved...what do you think..Finish Line may not keep this link active..
Thread Done..
https://www.rx8club.com/showthread.p...19#post3258119
Old Oct 3, 2009 | 02:54 AM
Lebren's Avatar
"The good is whatever brings the greatest happiness to the greatest number of people" -J Bentham
Good to see FLP still has these TSB's
Old Oct 3, 2009 | 07:12 AM
mkmike103's Avatar
Swoope, you didn't have to go through the trouble of finding it for me.. Thanks for your time though, I'll give it a good read and fix what is necessary.
Old Oct 3, 2009 | 10:35 AM
champi0n's Avatar
i was under my car the other day and my oil pan is all rusted on the bottom (I think i hit something that caused a dent/scratch) and now its rusting pretty good...
anyone have an idea how much a new one costs? (doubtful I can find one from a junk yard around here)
Old Oct 3, 2009 | 01:05 PM
mkmike103's Avatar
Pretty sure you'd be looking at a couple hundred dollars. From the tsb mentioned above looks like the sensor is inside the pan itself? Not entirely sure on the cost though.
Old Oct 3, 2009 | 01:08 PM
Lebren's Avatar
mazdatrix has one for under 160, rust and dents are not uncommon especially if you're lowered
