Where is DRL Module
Old Aug 25, 2009 | 08:46 PM
Snrub's Avatar
Question Where is DRL Module
Hi,
Can you tell me where the DRL module is and how I can test it? I have a service manual that I downloaded online, but it doesn't seem to list the DRL module. I've searched the forum, and apparently it's somewhere under the glove box, but that doesn't identify it or tell me how to test it.
My problem is that my high beams and daytime running lights do not work. I have checked the headlight relay, fuses and the headlight switch (of course even in a modern premium car interior parts are only made to be assembled once, so now it will never look as good, will rattle, etc.. ) and everything is okay.
I'm getting a bit frustrated, I've had this car for 5 months from 22-28,000 kms (13-16k miles) and I have had four problems already. My previous cars (owned during overlapping periods) a '87 RX-7 and '98 Protege had a better track records than that.
Thanks.
Old Aug 25, 2009 | 08:48 PM
Jon316G's Avatar
Grasshopper
Page 57 in the Electrical manual
Old Aug 25, 2009 | 08:52 PM
Jon316G's Avatar
Grasshopper
Page 229 in the Body manual goes over removing and inspecting the DRL module.
Old Aug 25, 2009 | 08:59 PM
Jon316G's Avatar
Grasshopper
Have you verified the switch itself is ok?
If you have fog lights, do they come on when you turn the switch?
How about the rear side markers?
Looking at the electrical diagram I can't see it being a fuse or relay unless you have two separate issues.
Old Aug 25, 2009 | 09:24 PM
Snrub's Avatar
I had that html version of the manul which doesn't seem to be nearly as useful as the PDF. You made me realize there was a PDF. I found a pdf version of the body manual (electrical won't download, but I don't need it due to your posting) and went to the page you specified. I'll check it tomorrow evening and let you know how it goes.
Yes I did verify that the switch itself is okay on the high setting. What are flood lights, do you mean fog lights? If so, they work.
Old Aug 25, 2009 | 09:26 PM
Jon316G's Avatar
Grasshopper
OOPS... yes, I meant fog lights. My bad... fixed
Old Aug 26, 2009 | 06:11 PM
Snrub's Avatar
The values I'm reading seem to be different from what the manual specifies. I think I'll try replacing the DRL module. When the part comes I'll let you know how I make out. Mazdamotorsports doesn't have it in stock, so I imagine it's going to be a long wait with my super competent local Mazda dealer.
Thanks for the help.
Old Aug 27, 2009 | 06:48 PM
Snrub's Avatar
Replacing the DRL module didn't help.
My GF noticed both bulbs have some black in them. Is that in any way normal? Is it possible that both bulbs blew at the same time? They're not wired in series are they?
Old Aug 27, 2009 | 06:55 PM
Jon316G's Avatar
Grasshopper
They're not in series.
Might be time to check for voltage at the socket.
I also noticed the current runs through the FOG relay before the DRL Module.
Just something else to throw out there.
Old Sep 12, 2009 | 03:43 PM
Snrub's Avatar
Ugh, it turns out that I had two dead bulbs. (my GF was right - she's standing over me to make me say that
vapor2
Jul 9, 2016 07:35 AM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
ErwinN
Sep 23, 2015 09:29 PM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
stickmantijuana
Sep 4, 2015 10:31 PM
