coolant system
Old Aug 25, 2009 | 12:55 PM
isLoTz's Avatar
bente doz
coolant system
im new to this stuff
just wondering what kind of coolant do you guys use?
and how do u guys use them?
when i mean?
Old Aug 25, 2009 | 01:07 PM
JinDesu's Avatar
went back to srsly broke
You can use the Mazda OEM coolant, which you can purchase at the dealer.
There are a few others you can use (i believe not the orange one). You can mix your own coolant, the OEM one is 60 alcohol/40 water i believe?
Old Aug 25, 2009 | 01:10 PM
isLoTz's Avatar
bente doz
you cannot buy that somewhere like pepboyz, kragen, etc?
Old Aug 25, 2009 | 02:05 PM
JinDesu's Avatar
Search in this forum for the mixture. The Mazda FL-22 OEM coolant is basically 60/40 or 50/50 (I can't remember) coolant. There's nothing special about it. If you can find a coolant from any of your average autoshops that have the same mixture, then you can use it.
Some people say don't use orange colored coolant, which when mix with the one in your car will turn black, but other say it doesn't matter.
Old Aug 25, 2009 | 03:23 PM
I use prestone anti freeze
70% water
30% anti freeze
1 bottle of water wetter.
Old Aug 25, 2009 | 03:38 PM
ndhoffma's Avatar
Id search around & look in your manual as well... I know different regions use different mixes (i.e. 70/30 if it is very warm, 60/40 in cold areas)
I used prestone last time i re-filled mine. There is a DIY on this here somewhere
Edit: https://www.rx8club.com/showthread.p...ht=coolant+DIY
Old Aug 25, 2009 | 04:54 PM
eva02's Avatar
70% water
30% anti freeze
do you know what temp's you're running?
u know at idle,while driving during acceleration.
Old Aug 25, 2009 | 05:33 PM
of course I do, I've got digital temperature gauges.
Old Aug 25, 2009 | 05:37 PM
eva: that really is one of THE hardest questions to answer though as temperature can fluctuate quite dramatically based on ambient temperature and my particular driving style at the moment.
I will say this; if the outdoor temps are 70-85°, I'll usually cruise on the freeway at around 172°. If I get on the throttle, that can quickly get up to 200 but will settle back down after a while.
I have upgraded my entire cooling system though so my results may not be typical.
I currently have:
- BHR Radiator
- Mazmart Water Pump
- Mazmart Thermostat
- AccessPORT tuning by MM
I see that you live in the I.E. so lately you're seeing 85 - 95°F temps?
I would expect city driving temps to be in the 195 - 210° range for your car. (assuming stock cooling)
Above 95° is when the OEM cooling system starts to struggle. I was out in Riverside last year (prior to upgrading my cooling system) and I was seeing 220°F if I got on the throttle.
Keep in mind: if your stock temperature gauge starts moving, you are ALREADY heat soaked and should be very careful. (I believe that needle starts to move once you're at approx. 230°F )
Old Aug 25, 2009 | 05:38 PM
I want that oil temp gauge.
Old Aug 25, 2009 | 05:40 PM
I'll sell you one.
$100 shipped.
Nordskog should really pay me commissions for all the people I send them.
Old Aug 27, 2009 | 08:50 AM
isLoTz's Avatar
bente doz
the light on my engine coolant system came up
and im having trouble if im going to take it to dealer or just buy a coolant?
but idk which one to buy?
i just found out this morning
help?
Old Aug 27, 2009 | 09:08 AM
Huey52's Avatar
Registered Zoom Zoomer
I use the pre-mixed (50/50) Prestone long duration. Or the GM Dextron stuff. Both are FL-22 compliant.
Old Aug 27, 2009 | 09:10 AM
isLoTz's Avatar
bente doz
where do i get it?
Old Aug 27, 2009 | 09:11 AM
isLoTz's Avatar
bente doz
its already mix?
or should i still add water?
sorry im kind a new to this stuff
Old Aug 27, 2009 | 09:18 AM
quazmosis's Avatar
Chode
If its 50/50 you dont have to mix it. That means 50% water, 50% antifreeze.
Old Aug 27, 2009 | 09:19 AM
isLoTz's Avatar
bente doz
thanks..
but which one u prefer to use?
Old Aug 27, 2009 | 09:20 AM
quazmosis's Avatar
Chode
Jedi how much was that gauge cluster of yours, and where do i get it?
Old Aug 27, 2009 | 09:21 AM
quazmosis's Avatar
Chode
I use the Prestone stuff. As long as its FL-22 Compliant, others should work too.
isLoTz's Avatar
bente doz
he's not online yet
isLoTz's Avatar
bente doz
so just put some on it on the coolant engine and thats it?
Old Aug 27, 2009 | 09:22 AM
quazmosis's Avatar
Chode
he's not online yet
Oh he will be. He will be.
Old Aug 27, 2009 | 09:23 AM
quazmosis's Avatar
Chode
Well you put it in your coolant resivour. Up to the F Line.
isLoTz's Avatar
bente doz
im so worried about this coolant system light that came up this morning to my 8 and i dont know what to do...lOL
funny weird huh??
Old Aug 27, 2009 | 09:28 AM
quazmosis's Avatar
Chode
It may be the sensor that's going out as well. A fairly common problem. You might go to fill and see that you are already full. Or you might top it off and the light doesnt go off. Then I would suspect its your sensor.
