security light
Old Aug 24, 2009 | 05:16 PM
tan601's Avatar
RXAtE
TX security light
Parked the car last nite no problems. Tried to start in the morning, only heard a small click then the security lite began to flash rapidly. Several more tries no good. Disconnected the battery, reconnected same thing. Is there any thing I can do other than you know the dealer.
Old Aug 24, 2009 | 05:19 PM
Jon316G's Avatar
Grasshopper
Lets start with the basics...
Did you check voltage at the battery?
You might have enough voltage to power some lights, but nothing major like the ignition or starter.
Old Aug 24, 2009 | 05:38 PM
tan601's Avatar
RXAtE
13.8 volts
Old Aug 24, 2009 | 05:46 PM
Jon316G's Avatar
Grasshopper
Have you tried your spare key?
Old Aug 24, 2009 | 07:20 PM
Flashwing's Avatar
3-wheeler
If the security light is flashing while trying to start it's because it doesn't recognize the key that you are using. As Jon stated I would try your spare keys and see if that does the trick. If the immobilizer lost the key programming the dealership will need to reprogram it.
Old Aug 24, 2009 | 09:18 PM
I8U's Avatar
I8U
You blew a fuse in the engine fuse box...I know from first hand experience. Check all the fuses but take a close look at the ENG fuse under the hood, it's most likely your culprit.
Old Aug 25, 2009 | 07:16 AM
tan601's Avatar
RXAtE
None of the above Kinda except the fuse was kinda close, I hooked up a program from my laptop to the OBDII It told me no PCM input. So I could not run a diagnostic. Located the computer PCM . Found a loose connector. Strange though the connector will not lock in place, looks as though it will not lock in place . A drop of silicone to hold it in place. Back in business. Thanks every one for the suggestions.
Old Aug 25, 2009 | 10:48 AM
09Factor's Avatar
Original Turbo 'd Auto !!
Would you supply us with a pic of the loose connector you found?
Old Sep 5, 2009 | 06:50 AM
JohnLee_Fin's Avatar
Aah i have the sma problem and my car was working perfect and when i was tried to start in morning the security light was flashing!
I have check out the battery and it was okey and all fuses next to battery and inside the car and they are all perfect.
Also i have another key , but the same security light still flashing with that key.
what i should try to next?
please can you someone send me a pm and help me out of this
Old Sep 6, 2009 | 03:21 AM
My eight is working perfect now it was the battery!
Thank you guys for help!
cliffkemp
Dec 24, 2024 10:48 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
