View Full Version : Spark Duration
auzoom
08-23-2009, 07:32 PM
Following on from a comment in the Coil Dwell thread, I have some questions on spark duration.
The main question I have is, is spark duration a function of the spark plug, the coils or the ECU?
I am guessing its the ECU. Depending on the answer I have a bunch of other questions.
Cheers
Andrew
MazdaManiac
08-23-2009, 07:46 PM
Coils. The collapse of the field only takes a few microseconds and is not sustainable.
auzoom
08-23-2009, 10:36 PM
Awesome...thanks :) So now I want to find out if there is published data (like this http://www.dtec.net.au/Tech%20Articles/Ignition%20Coil%20Energy%20Testing.pdf) on spark durations and energy across different coils.
madcows
08-27-2009, 12:50 AM
Auzoom, there should be plenty of data related to high voltage coils (not just auto specific) all over the net. But if you're trying to find data on a specific group of automotive coils, then it might be a bit difficult. Many manufacturers of aftermarket units specify their output energy and duration.
auzoom
08-27-2009, 01:03 AM
I have only managed to find a small amount of data from some independent tests like I posted up. I am an electronics dunce so while I would love to try the tests in that link I would probably electrocute myself!
