Clank from Park to Reverse
Old Aug 22, 2009 | 08:52 PM
ou_joshua's Avatar
Hey guys, I noticed today when i shifted from park into reverse it made a clank noise. Its not too loud, i cant hear it with windows down. And it seems to only be audible when its cold. Can someone help?
Old Aug 22, 2009 | 09:18 PM
mysql101's Avatar
abs test is the sound you usually hear when first moving the car
Old Aug 23, 2009 | 09:17 AM
ou_joshua's Avatar
Old Aug 23, 2009 | 09:39 AM
Easy_E1's Avatar
This with the car stationary? And you just shift it into reverse with your foot on the brake and it goes clank,correct?
Old Aug 23, 2009 | 02:02 PM
ou_joshua's Avatar
yea. or maybe slight roll cuz its downhill
Old Aug 24, 2009 | 08:03 PM
ou_joshua's Avatar
Old Aug 24, 2009 | 08:14 PM
Easy_E1's Avatar
Sounds like the universal joint on the drive shaft.
Put the car in Park, put the emergency brake on. Jack the car up. Install the appropriate safety stands under car. Crawl underneath and put your hands around the drive shaft. Now rotate it with opposite force left and right. And see if you hear the noise.
Old Aug 24, 2009 | 08:28 PM
ou_joshua's Avatar
i will try this. today when i was leaving, i let my idle roll down near 1k before shifting to reverse, and was on flat ground and no sound came out. but this weekend i willl try checking
theblinkof
Oct 4, 2023 05:24 PM
pjwermuth
Sep 28, 2015 11:36 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
superROB23
Sep 4, 2015 01:22 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
