Removing wax question
Old Aug 21, 2009 | 09:06 PM
ekwok117's Avatar
I'm pretty sure this is a stupid question...but I'm going to ask it anyways.
I washed, clayed, and waxed my 8 for the first time (the claying and waxing part) the other week only to realize I have some horrid swirl and light scratches all around...probably from me not knowing how to wash before and from the previous owner. I just bought some meg swirl x and my question is, do I have to remove all the wax before applying it? Also, should I get the scratch x as well?
Thanks and sorry for the stupid question.
Old Aug 21, 2009 | 10:57 PM
rodjonathan's Avatar
silent assasin
yeah get em both and i would clay it again before using those products works better and more thorough
Old Aug 22, 2009 | 07:37 PM
ekwok117's Avatar
which would I use first?
Old Aug 23, 2009 | 12:20 AM
silent assasin
clay then either one is fine i would use scratch x then swirl x but i think either way would work ...
Old Aug 23, 2009 | 12:35 AM
StealthTL's Avatar
Metatron
For wax removal. only a solvent will take it ALL off.
Use what we use before we apply graphic logos, adhesives or decals - IPA.
Isopropanol or isopropyl alcohol and a big soft towel, spray it on liberally and wipe off, turning frequently.
If you don't use at least a pint (500ml) you haven't done it right......
Old Aug 23, 2009 | 03:15 PM
Jethro Tull's Avatar
Living In The Past
The best solvent for wax is methylene chloride. Except that it also removes your paint and is a known carcinogen! So milder solvents must be used in combination with elbow grease. Alcohols on wax will take a lot of repetition and a lot of alcohol.
Old Aug 30, 2009 | 05:01 PM
Jim D.'s Avatar
Either product you're using will remove wax in the the process of using it - you don't need anything special.
Swirl-X would be what I would try first. If that doesn't work, try Scratch-X as it would be more aggressive.
Consult with Meguiar's tech support forum if you don't get the answer you're looking for here.
Old Aug 30, 2009 | 05:04 PM
ZumnRx8's Avatar
RX8 & RX7 owner
oh dam i thought this was about sex wax....
Old Aug 30, 2009 | 05:42 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
As only a surfer might know..................
Old Aug 30, 2009 | 05:44 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^Yessssssssirrrr. lol, BTW Cali>Florduh
Old Aug 31, 2009 | 10:39 AM
Bigbacon's Avatar
2006 WB AT
i've been doing wash, clay, swirl X, wax if I go the full yard to clean the car.
other wise I just wash and do a detail spray of the car.
Old Aug 31, 2009 | 03:20 PM
Using simple Dawn dish soap is the gentlest on your paint. It'll strip your car of any previous wax ( which is what you want)
1. Wash car with Dawn dish soap
2. Clay bar using a lube comprised of your regular car wash soap
3. Apply waxes in the order they specify
4. Apply a UV sealant when ALL waxing layers have been finished
Old Sep 5, 2009 | 10:35 AM
exceldetail's Avatar
Common sense prevails here. Use the polish, thats what theyre meant to do......
Old Sep 17, 2009 | 01:50 AM
TorqueyPig's Avatar
Use a super fine compound and buff that bad boy
Old Sep 17, 2009 | 01:54 AM
nikkdizzle's Avatar
Daddy's Home...
i think if you use a mild dish washing soap it will remove the wax, then wash again with regular car wash...clay/polish/wax again...
gwailo
May 14, 2024 06:57 AM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
