Rattling Sound around 5.5k rpm (video attached)
Old Aug 17, 2009 | 09:56 PM
afai's Avatar
Engine Rattling Sound around 5.5k rpm (video attached)
Hi,
Here is the link to the video
http://www.youtube.com/watch?v=W7vjEhKJztY
and
http://www.youtube.com/watch?v=LR-dRYHGh0g
I have a 2004 rx8 auto and it is around 96000km/almost 60000mile
Have this weird sound for quite a while. I change the coil, spark plug, and wire last year. But didn't change anything. The sound is getting worse. It get louder if the temperature outside is cooler.
What is causing this weird sound? Any one has any idea?
Old Aug 17, 2009 | 09:59 PM
Atilla's Avatar
I am THAT guy
could be wrong on this...but sounds like your catalytic converter is gone
Old Aug 17, 2009 | 10:02 PM
afai's Avatar
would it also cause rattling at idle
Old Aug 17, 2009 | 10:13 PM
Jon316G's Avatar
Grasshopper
I have rattle sounds when there are pens in my glove box or in the storage area in the door.
Old Aug 17, 2009 | 10:20 PM
Atilla's Avatar
I am THAT guy
^+1 sad but true. Some times the obvious is overlooked. Good to check that first
but yes, a rattling noise is still heard at idle.
Old Aug 17, 2009 | 10:23 PM
afai's Avatar
definately nothing to do with physical item in glove box or the door storage area.
The rattle sound can be significant louder when weather is colder.
Old Aug 17, 2009 | 11:45 PM
Rosey's Avatar
I noticed the same noise today when I was on the freeway. I noticed it between 4-6000 rpm. I took it in for a diagnostic test and I'll let you know what they tell me. With me, I could only hear it when the car warmed up a bit.
Old Aug 18, 2009 | 12:40 AM
volcomx31's Avatar
Silver Power
how did you get up to 100 MPH on 2nd gear ?
Old Aug 18, 2009 | 01:29 AM
afai's Avatar
km not mile
Old Aug 18, 2009 | 04:48 AM
rx 8speciale's Avatar
Relax baby!
engine mounts ....
Old May 24, 2010 | 09:12 PM
Khmersinista's Avatar
I think I have this same problem. It doesnt rattle when its cold but when the temp goes up it does.
Old Jun 1, 2010 | 11:04 PM
cstishenko's Avatar
Kelownafornia
Update on this boys?? Same issue here..
Old Jun 17, 2010 | 07:15 AM
0rph3n's Avatar
my '04 mt (67k km) did the same noise from 6.5k rpm till redline (only if floored).
i used to think that the cause was dead cat, but sunday i tried to premix for the first time (100ml in 3/4 tank) and the noise disappeared!
2 things that come to my mind:
  • the omp has something wrong and don't provide the right quantity of oil
  • the cat is really gone and cause the engine temp to raise, so the "standard" amount of oil provided by the omp is no more enough to cool the engine
my 2 cents
please, feel free to notify any error of my english
Old Sep 4, 2010 | 09:26 PM
DHPrx8's Avatar
Sorry to bring this post back to life - however - the sound in this post is exactly what I am hearing - cold I am fine - warm engine hear this crackling noise in 5-6 rpm range. Manual 04 - 156K - original engine - Changed out coils, wires, plugs. Seafoamed too! Also goes into "limp" mode with no power on load and crackling gets worse. I put in fuel injector cleaner mix - did help a little.
Now my CEL has come on with a p2096 - so i cleaned the MAF/IAT - replaced the O2 Sensor about two weeks ago because got a CEL on postion 2 OS sensor.
Wondering if this crackling (sounds like fuel starvation - misfiring) is a sign that the CAT is burned out?? Would heat up of the engine (and cat) make the engine struggle fuel wise and therefore create this noise? Would a semi-blocked CAT create this issue?
I just obtained a stock cat from a fellow Rx8 member and will install that tomorrow - but I just have a hard time understanding how a CAT problem can relate....
Any comments would be apprieciated - and I will be sure to report back my findings because it drives me crazy when I am reading a posting and it just ends without any comments on the final outcome or solution!!!!!!!!!!!!!!!! grrrr.....
Old Sep 4, 2010 | 10:47 PM
Old Rotor's Avatar
Fuel pump.
Old Sep 5, 2010 | 03:04 PM
cstishenko's Avatar
Kelownafornia
we traded ours in, because noone knew. After I was $1200 in trying to find it... we said thats enough.
I'd like to know what you guys find.
Old May 15, 2013 | 09:22 AM
Faxie's Avatar
3 Year kick.... but are there any updates?
I got the exact same problem as DHPrx8. Same rattle sound, same rpm's, and occasional p2096...
Old May 15, 2013 | 09:25 AM
paimon.soror's Avatar
i would get your fuel pump tested asap.
more info will help:
miles
mods
maintenance
Old May 15, 2013 | 05:56 PM
Faxie's Avatar
Only a RB exhaust. Coils and sparks are brand new, clean MAF and intake regularly, checked the VFAD operation and is just fine. Can't find any vacuum leaks.
Almost 100k miles, runs fine apart from the rattle from 5-6k. No rattle when slightly accelerating, only on WOT. Slight power loss as well, but goes to readline.
First thought was cat, but will check the fuel pump. (Tried to get it loose earlier, but that's a pita without proper tools... )
Car 's bit difficult to start when hot and within a few minutes from shutoff. Battery's fine and got the faster starter motor. Sign of a bad fuel pump as well?
Old May 15, 2013 | 06:15 PM
check cat as well just to be safe. generally people that have catalyst failures can't rev up too high without a serious loss of power, but better safe than sorry. But with the code you have I would lean more towards fuel pump. Some people use a screwdriver and a hammer to try and get the retaining ring off. Just be careful of the tabs that break easily.
Old Aug 18, 2019 | 04:49 AM
RN-RX8's Avatar
Originally Posted by afai
Hi,
and
would be nice if this video link was still up...
Waylon Chen
10
Sep 29, 2014 09:47 AM
gjase
Nov 16, 2007 01:52 AM
DOMINION
Suggestions Archive
Jun 9, 2006 09:38 PM
thklam
Jul 30, 2003 07:29 AM
