RPM of Renesis
Old Aug 17, 2009 | 05:05 PM
renesisgenesis's Avatar
mod edit
RPM of Renesis
I have heard various comments on the actual rpm of the renesis/actual ignition fires, etc.
But what I am curious about is:
Is the flywheel rpm going to match the tachometer?
Old Aug 17, 2009 | 05:16 PM
Old Rotor's Avatar
Yes....What you probably heard was the rotors are 1 cycle to 3 cycles of the crank.
Old Aug 17, 2009 | 06:05 PM
CyberPitz's Avatar
Huge hole is huge
The Eccentric shaft is the measuring factor of your RPMs. Every one revolution of the Rotor is 3 rotations of the eccentric shaft.
Old Aug 17, 2009 | 06:18 PM
Easy_E1's Avatar
The the tachometer is run by the Eccentric Shaft Position Sensor. So yes the flywheel speed is the same as what the tachometer is displaying.
Old Aug 17, 2009 | 06:20 PM
MazdaManiac's Avatar
http://www.youtube.com/watch?v=OuId4nuxXaM
Old Aug 17, 2009 | 06:24 PM
CyberPitz's Avatar
Huge hole is huge
*Looks at avatar
Wants to click youtube link
Realizes no **** on youtube
doesn't click link*
Old Aug 17, 2009 | 06:35 PM
04RX8man's Avatar
Rotary Powered Countryboy
^lmmfao!!!!!!......haha
Old Aug 17, 2009 | 06:36 PM
04RX8man's Avatar
oh forgot about the Op as other said yes flywheel rpm=eccentric shaft rpm...
so at 9000 rpm the rotor is technically spinning at 3000rpm....
Old Aug 17, 2009 | 06:41 PM
User24's Avatar
Then, why don't the rpm gauge just max out at 3000. This is like those japanese motorcycles that show higher rpm than actual.
Old Aug 17, 2009 | 06:45 PM
04RX8man's Avatar
piston car rpm=crankshaft rpm
rotary car rpm=ecc. shaft rpm
it's measuring the rotationi of the engine which is crankshaft/ecc. shaft
Old Aug 17, 2009 | 06:53 PM
User24's Avatar
So the piston is really gauge / 2, and renesis is gauge / 3 huh.
Old Aug 17, 2009 | 07:04 PM
mod edit
The flywheel rpm is what ultimately matters. That is what connects the motor to the clutch/transmission/wheels. apparently, on both piston and rotory cars, the tachometer matches the flywheel rpm, so there would not be any sense in making the rx8 tach show 3000, because the flywheel really IS going at 9000 rpm.
If the rx8 was at only 3000 rpm, there is no way 159 pound feet of torque would get 232 bhp; in fact, it would be impossible to even get 159 bhp, sense bhp and torque are always identical at 5252 rpm, and below that, torque is always more.
"idiots".
damn, MM beat me to the punch.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
