heyarnold69
08-16-2009, 08:28 AM
Please create a set: Interior (all), Tail Lights (all inc 3rd break light), Smaller set -- Turn signals/ parking lights
Master set. Everything !
Thank you --- I shall await your response with pricing information.
RotaryFX.com
08-19-2009, 06:13 PM
Thank you for your inquiry. Unfortunately, we are not able to create a set with those bulbs.
We do carry the following bulbs on our new web site.
Interior LED Bulb Set (Doors & Dome):
http://www.rotaryfx.com/product_p/lig1004.htm
Map LED Bulb Set:
http://www.rotaryfx.com/product_p/lig1006.htm
Tail Light Super Bright LED Bulb Set
http://www.rotaryfx.com/product_p/lig1030.htm
Parking Lights Super Bright LED Bulb Set
http://www.rotaryfx.com/product_p/lig1023.htm
Our lighting category:
http://www.rotaryfx.com/Mazda_RX8_Lighting_s/2.htm
The best way to determine pricing is to place the items into your shopping cart. Available shipping methods and prices will be shown prior to checking out.
If you have additional questions, we would be happy to help you. Please contact us through our web site here:
http://www.rotaryfx.com/Articles.asp?ID=132
Thank you,
Heather
RotaryFX.com
(formerly RX8strakes.com)
klanham08
08-23-2009, 11:09 PM
I just purchased the Interior Light Set, I will let you know how they look once I install them.
doug2009
12-01-2009, 03:12 PM
I bought the interior LED set, map light set, glove box, footwell kit and license plate LED's all in Blue for my daughters RX8. Gets many looks and compliments!! I'm very satisfied with them. I also got the clear side markers with bright white led's.
However the super bright parking light led's probably look good if I could get them to go in. The drivers side was a pain and it finally went in. But I couldn't get the passenger side bulb to fit inside. So I decided to go back to the original bulbs. So, when I pulled the led out of the drivers side, the bulb fell out and is now sitting inside my light waiting on me to figure out how to remove it. I even put tape on the bulb and since it was such a tight fit, it still fell out. If it was that hard to go in I can only imagine how hard it's gonna be to fish out, if at all possible.
It's a 2004, and from what I can tell, there is some sort of build up around the lens opening right before the bulb goes into the lens. I'm guessing these bulbs install better with the newer RX8's.
I was wondering if anyone else has had this same problem with the parking light LED's from RotaryFX.
sbala
12-11-2009, 07:47 AM
I had the super bright tailight bulb set & wiring harness installed but the turn signals flash at a much higher rate than the OEM bulbs did, any advice on how to correct this so that they flash slower?
RotaryFX.com
12-12-2009, 02:54 PM
Use the included load resistors to fix the "fast flash" of the turn-signals.
-Dave
