need expert tech. support
Old Aug 14, 2009 | 10:00 PM
turboz00m's Avatar
TX need expert tech. support
so ok. i have had my rx since feb. its a 2005 automatic. since may i believe i have been having problems with the engine stalling out when i come to a stop. i took it to the dealership and they said it was carbon build up. so i removed the carbon from my engine according to the DIY forum and now it takes forever to start and today it stalled out on me. i've put fuel additives in and the car seems to run perfect on them. but that is just a temp solution to a big problem. now when i shift into triptronic and rev it to 7000 i notice in second gear it makes a cluttering noise like something is backfireing or even rubbing. it only makes that noise in second gear and only between 5000-6500 rpms. this is driving me nuts. when i come to a stop the car idles erractically and then dies. once it hits 500 rpms sitting it begins to feel like its losing power then stalls out. takes 5-20 mins b4 it starts again. i noticed one time i started it up after it stalled and i revd to 6000 in park and i could smell a weird smell. idk if any1 has any ideas what it could be please help. i plan on taking it to the dealership in 2 weeks once i get paid again. mazda will probably decarbon it and tell me its fixed..but i already decarbond it so w.e i dnt wanna waste $100 gettting it decarbond again if thats not gonna solve the problem.
Old Aug 14, 2009 | 10:01 PM
Spinning Sushi's Avatar
I <3 Sushi
I'd first check your coils and plugs.
Old Aug 14, 2009 | 10:03 PM
turboz00m's Avatar
mazda replaced them bout a month ago.
Old Aug 14, 2009 | 10:06 PM
I <3 Sushi
If I remember correctly, there's a TSB for the torque converters on the 8 for the bad and rough idle. What they do is replace the torque converter with one from a 2009.
Low Fly'n 8's Avatar
My 2004 (6 MT) had the same symptoms at around 65,000 miles. They did the de-carbon treatment and then it would not idle at all. At that point they replaced the motor. Your motor core is warrantied for 100,000 miles.
Old Aug 14, 2009 | 10:07 PM
turboz00m's Avatar
well it would be sweet to get a new engine...
Old Aug 14, 2009 | 10:10 PM
shakeyourbrakes's Avatar
Im guessing your over 100k on the car?? if not your getting screwed, what up with the warranty on the car, obviously if theres an engine problem theyre going to cover it under warranty and you have nothing to worry about..
if your are over 100k, i agree it sounds like it may be a coil/plug issue
Old Aug 14, 2009 | 10:12 PM
rodjonathan's Avatar
silent assasin
yup new engines are always sweet
Old Aug 15, 2009 | 08:27 AM
turboz00m's Avatar
i only have 47k miles on car.
Old Aug 15, 2009 | 08:40 AM
amberlayne's Avatar
I been having the same problem. I have 04 the dealer has fixed everything im now waiting on a oxygen sensor!!
Old Aug 15, 2009 | 09:28 AM
Easy_E1's Avatar
Take it to the dealer and tell them you've noticed a loss of power and hard starting and it stalls when you come to a stop.
It's time for a new engine. And I would have them check the Catalytic Converter.
You have warranty on both still.
Shankapotamus3
Mar 14, 2021 03:53 PM
nadodave
Aug 28, 2019 05:55 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Austin22
Sep 23, 2015 04:46 PM
