175,000 Mile Club Member needs help
Old Aug 14, 2009 | 09:46 AM
jmil's Avatar
Angry 175,000 Mile Club Member needs help
Alright - I have had Multiple CEL's including Misfire (sorry cant find my notes) but here is what i have done:
New Coils
New Plugs
New Wires
New Fuel Pump
The power is back - Stuttering under load is fixed but the car will not Idle worth a darn. After resetting the Computer, Battery and Brake Method - I took it for a drive (NO CEL) and it seemed fine. Shut down restarted and Steady CEL and Low idle that it stalled. Went to AutoZone and they indicate a P0037Code.
That is the O2 Sensor He indicated Upstream and Downstream. Do I need Both Sensors????
Is the O2 Sensor the cause of my idle issues.
Will Seafoaming and Cleaning Engine Possibly correct this as I never did it but I have the Seafoam here and am mechanically able?
Thanks all!
Old Aug 14, 2009 | 11:15 AM
In a closed-loop system, you will need Front O2 Sensor for correct oxygen feedback, so the ECU will give the correct fuel/air mixture.
The rear one is just there to check CAT efficiency.
at 175K miles I guess your O2 sensor is about time to "give up", change it. about 200 something bux.
if you got new coils, plugs, wires and fuel pumps already, try new O2 sensor first, if it doesnt fix your problem, I will check the engine compression. then I will check the throttle body.
Old Aug 14, 2009 | 11:19 AM
rodjonathan's Avatar
silent assasin
god dam thats ALOT of miles yea sounds like the o2 sensor but not sure
Old Aug 14, 2009 | 11:36 AM
lepichichi's Avatar
I LuV mY Rotary....
175.000 miles on the original engine???
Old Aug 14, 2009 | 11:42 AM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
^+1 is it??
Old Aug 14, 2009 | 12:38 PM
jmil's Avatar
175,000 miles
Yes - Original Engine - I am a super commuter (250 miles a day) all Highway.
So I am getting - change the front O2 Sensor. Is there a DIY Thread (I did search).
BTW - Engine is pulling strong again (Compression Feels Good??) and what about seafoaming???
Old Aug 14, 2009 | 01:09 PM
well you drive a lot of highway miles so your engine should be pretty clean.
you can do it , follow my DIY, seafoam/zoom zoom cleaner is about the same.
its easy to remove the O2 sensor ---- as long as its not seized ! you need a O2 sensor socket. some PB Blaster, and some time.
Old Aug 17, 2009 | 09:41 AM
jmil's Avatar
Auto Zone
OK - I found the following Sensor and ordered it form AUTO ZONE ($181.00) for my P0037.
BOSCH 13772
Oxygen Sensor - OE Type - Exact Fit - Downstream Sensor w/ Manual transmission; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles
Anyone have any knowledge of this part and if its a direct swap?
Old Aug 17, 2009 | 09:48 AM
Macius8's Avatar
Original catalytic converter? Check that, it may be clogged.
Old Aug 17, 2009 | 11:57 AM
it could be a dead CAT, but I mean his O2 sensors are due Anyway. might as well change it.
Old Aug 17, 2009 | 01:41 PM
jmil's Avatar
Cat
It is the original Cat - But i did have big problems with the plugs. Wires and coils which are now all changed. The car runs very good with power now, just the issue with the CEL p0037 and the idling issue.
From what I read on the threads - The sensor can be damaged from the poor running condition it was in for an extended period, and the idling issue is most likely the Sensor (Hopefully this one (cat); and everyone else that has lost there CAT has had major Power issues and acceleration problems.
Well that is what i get from reading the threads. Lets keep our fingers crossed. Sensor will be in Wednesday. Hopefully Thursday I will post a 175,000 Mile car with no CELs and pass emission inspections on original engine and tranny!
Old Aug 17, 2009 | 01:48 PM
FazdaRX_8's Avatar
your over halfway there to 300,000 miles!!!!
Old Aug 17, 2009 | 02:09 PM
You already show us what miracle means ! 175 K miles on original CAT?! wow !
most die BEFORE it even got pass 50 K miles. mine dead when I was like maybe 15K miles.
Let us know how it goes
Old Aug 17, 2009 | 02:27 PM
**** I almost don't believe you!!! At my rate I'll be on engine 5 at 175k. One of my engines saw 90% highway miles and it lasted the longest (but still only 72k).
Old Aug 17, 2009 | 03:39 PM
04RX8man's Avatar
Rotary Powered Countryboy
^u just must not be redlining enough LMAO!!!!
Old Aug 17, 2009 | 03:40 PM
04RX8man's Avatar
Oh and 175k miles I'm VERY impressed and let's me feel that I have AT LEAST 125k more on my car!!!!
Old Aug 17, 2009 | 03:43 PM
Old Rotor's Avatar
New Coils
New Plugs
New Wires
New Fuel Pump
Thanks all!
How many miles did you get out of the plugs before they felt poor and had hesitation? Mazda says 37K, but we have people getting much more.
Old Aug 18, 2009 | 07:28 AM
jmil's Avatar
Plus and Coils
I get about 50K out of my plugs and Coils. The wires were just changed for the first time this week.
I do drive this car pretty aggressively - but I also cruise at around 80 most of the time with pushes above 100 on occasion so she is treated good but hard.
I am still waiting for my Sensor to come in - But i noticed last night on the way home that POWER was way down. Stark contrast from the day or 2 after I changed all the plugs coils wires. I am hoping it is the sensor then as the computer relearned itsself and doesn't know where to adjust. I do no have the cash for a Catalytic Converter and NJ requires no CEL Lights and emissions and my inspection expires in 2 weeks.
I was looking at the Rotary Cat from here:
http://www.rx7.com/store/rx8/rx8exhaust.html
Any one have this and know if the sensor is installed will it still show a CEL??
Old Aug 18, 2009 | 07:42 AM
Eish's Avatar
175 000 miles, damn, that is more than the 280 000 km my golf4 has done. And today it is at the dealer for driveshaft issues.
I have one question for you, how often have you been redlining your car?
Old Aug 18, 2009 | 07:50 AM
jmil's Avatar
On a daily Basis!
Daily at least a few times! Reason I got this car was I drive the NJ - NY System - Needed that Power to merge and switch, does a darn good job.
I am being real ginger with it now! Need that CEL to go away I am not sure what is wrong so I do not want to introduce another issue by being too hard on it!
Old Aug 18, 2009 | 08:05 AM
cyclone1208's Avatar
Wow 250 miles a day!!!! You must fill up like everyday
Old Aug 18, 2009 | 09:46 AM
That CAT is alright, but dont expect it to outlast your Stock CAT.
You can always go to some junk yard to find a wrecked RX-8, Im sure most wreck's RX-8's CAT will be in good shape. and most junk yards will sell it to you for cheap, maybe 100 bux. before you pay them, take a flash light and look inside to check for any signs of "melting", if u see any, no good, find another one.
Old Aug 18, 2009 | 10:42 AM
jmil's Avatar
Thanks- Just got a call part is in (Cat O2 Sensor) - Trying to get out of work to go get it and change it out!
Old Aug 18, 2009 | 12:30 PM
FazdaRX_8's Avatar
let us know. I am wonder that now that you have driven the car with a bad o2 sensor this will effect your air fuel ratio, and potentially just killed the cat
Old Aug 18, 2009 | 12:35 PM
jmil's Avatar
eeeek - I was thinking the same!!!
