once fixed more has broken
Old Aug 13, 2009 | 01:44 AM
p-trix's Avatar
So I replaced my radiator and water pump and also checked for leaks after everything was installed. No leaks. Next day my radiator light comes on and when i checked my coolant was low again. AND NOW my power steering has a mind of its own. it on its off... this just sucks
Old Aug 13, 2009 | 02:36 AM
Chavy's Avatar
I did it for the lulz
clean out the connectors under the intake for the power steering
Old Aug 13, 2009 | 02:40 AM
Brettus's Avatar
Boosted Kiwi
IF YOU DIDN'T PURGE THE COOLANT YOUR LEVEL WILL TAKE A WHILE TO EQUALISE
and +1 on cleaning/drying out the connector .
Old Aug 13, 2009 | 02:47 AM
well it takes a while for all the air to get out of the system. unless you were smart and filled it with the car jacked up in the front on jackstands..
as to the power steering.. well the radiator takes a dump on the connector for the power steering..
might search for that. also. know issues with sensor that controls the coolant light.
that light might have had nothing to do with the h2o pump or radiator..
Old Aug 13, 2009 | 12:40 PM
04RX8man's Avatar
Rotary Powered Countryboy
my recommendation is to lengthen the damn overflow hose on the coolant resivoir so it doesn't go right on the fan/ps connectors.....
Old Aug 13, 2009 | 12:58 PM
after he tinted his front window then he cried about being bitch by the cops ...
this is another failed.
Old Aug 13, 2009 | 01:20 PM
p-trix's Avatar
exactly
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
DeltaJ802
Sep 29, 2015 01:20 PM
kody59
Sep 28, 2015 03:43 PM
drlubell
Sep 26, 2015 11:58 PM
