new engine!!!
Old Aug 13, 2009 | 12:27 AM
jessedrifter's Avatar
so cal
new engine!!!
so ive been having alot of problems with my car and I finally took it in to the dealer for a compression check.(which was $175) A day later they called back and said they need to replace the two trailing spark plugs and coils for $150. At this time, I started thinking that they were gonna just have me pay to replace everything after they tested but the next day they told me that i lossed compression in rotor 2 which means im getting a new engine!!! They said, and i quote, " your gonna have a engine with 0 miles on it"... So is this technically true?? If so, do they change my odometer to 0? (and sorry im a noob) How many new engine owners had problems later with their so called "new engines"?
thanks guys
Old Aug 13, 2009 | 12:31 AM
tubingchamp's Avatar
What mawd bug?
Tach = RPM.
They won't reset your odometer, the odometer = KM on the CAR, not the motor.
It'll likely be a rebuild I think though. It's just as good as new, as the internals are brand new.
It will be just like having a new car though, engine wise. You'll need to do the break-in again.
Old Aug 13, 2009 | 12:38 AM
so cal
cool thanks man and sorry i meant odometer thanks ill change right now
Old Aug 13, 2009 | 02:54 AM
i am at over 65k miles with a rebuilt motor. it works fine.
make sure you get you money back for everything you have spent before.. as it was not the problem and did not fix it..
Old Aug 13, 2009 | 02:59 AM
Easy_E1's Avatar
I'm on #4.
Old Aug 13, 2009 | 11:55 AM
so cal
cool thanks guys.
and why 4 engines easy e?
and how does the warrenty work for you?
Old Aug 13, 2009 | 12:05 PM
so cal
Old Aug 13, 2009 | 12:41 PM
thanks guys
unless you are really lucky, you will most likely get a Remanufacture engine from somewhere.
Hmm, I think its time for you to ask them for a refund of everything that you've paid, cuz OBVIOUSLY the compression check was a fat lie, the coils and plugs u paid were not the cause. so yeah, if I were you, I will ask for a refund on those items.
Old Aug 13, 2009 | 12:53 PM
Bigbacon's Avatar
2006 WB AT
Actually, if you paid for these items just get them back and save them for when you need them.
Old Aug 13, 2009 | 01:23 PM
so cal
they refunded me the money for the compression check, but ill talk to them about the coils and plugs.
Old Aug 13, 2009 | 01:24 PM
so cal
and thanks guys
Old Sep 25, 2009 | 08:12 PM
dag14qb's Avatar
i lost compression on my 04 w 51k on it. did the plugs, coils, wires, and needed a new battery. its gonna be 1150 otd. the coils, plugs, and wires did not fix so i am getting a new motor. it has been running shitty for some time, but i am fine paying it, cuz i will have new plugs, wires, coils, and motor for a little over a grand. i just want it to run like the day i bought it. cant wait to drive it next week when i get it back.
Old Sep 25, 2009 | 11:41 PM
Old Rotor's Avatar
I put in OEM plugs, coils, wires, and a good quality battery for $310 in about an hour. How many dollars an hour do they charge? Must take them 6-7 hours or you are paying double for your parts.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
cschoeps
Aug 6, 2015 12:44 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
