Power loss at 7k, almost like a rev limiter
Old Aug 12, 2009 | 07:38 PM
chedda_j's Avatar
I had an issue with a small bogg at 7 grand ever since i baught the car but on a recent trip to vancouver the car just about lost all of its power after 7. Its so bad that the car nearly stops when it hits 7. i have a check engine light on but it only says bank 1 too lean, wonder if my injecter is f'ed. Please help guys. the car only has 11k on it.
Old Aug 12, 2009 | 08:27 PM
08boostedmzda's Avatar
If the car only had 11,000 miles on it then whatever is wrong should be covered under warranty
Old Aug 12, 2009 | 11:04 PM
Yep bring it in under warrenty. Bad coils?
Old Aug 15, 2009 | 07:01 PM
alex12345rx8's Avatar
I actuallly have had something like that happen to me too. Sometimes if the car hasn't warmed up and I rev to 6 or 7 k the power will drop off. Once it's warm I don't have an issue.
Old Aug 15, 2009 | 07:44 PM
WTBRotary!'s Avatar
Drummond Built
well it could be fuel cut-off no? If i remember correctly the ECU will have a fuel cut-off until your in normal operating temperatures... besides its very bad for you to rev your engine when its cold anyways... which is why Mazda implemented the fuel cuf-off before you get to normal operating temps... I could be wrong though...
Old Aug 15, 2009 | 11:27 PM
04RX8man's Avatar
Rotary Powered Countryboy
^the PCM wont' let you rev THAT high if it' not warm....I'd go to the dealer and have them check it out.....since you're under warranty....
Old Aug 16, 2009 | 12:14 AM
what year?
did you buy new or used?
sounds like you're probably still under warranty so I'd get it checked out. I'm leaning towards coils or a bad cat. (though it sounds awfully early in the game for that)
Old Aug 16, 2009 | 12:39 AM
hakuna matata!
um,, what the hell? you are revving the car up that high when it is not warm?
that would be the ECU kicking in and attempting to make this car idiot-proof.. seriously.
Old Aug 16, 2009 | 01:06 AM
04RX8man's Avatar
^but the PCM won't let it rev that high cause at 7k it easily can cause damage....I think the pcm limits revs to like 4k when cold...
RevMeHarder
Jun 1, 2026 02:30 PM
ladnarf1
Apr 29, 2021 11:53 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Kanthinar
Dec 21, 2015 01:24 PM
ed0128
Sep 9, 2015 04:50 PM
