Did my engine just go out on me?
I have an 04 rx8 manual with 56k on it and on my way back to the office on the highway today it started lunging back and forth....and then the check engine came on and started blinking. I made it to my exit and it basically went into a kind of safe mode where there was barely any acceleration. I thought I may have ran out of oil but that isn't the case. When I got to a parking lot i stepped on the accelerator and you could head like a poof sound coming out of the exhaust and then it stalled. It smelled like coolant out the tailpipes and under the hood. It had stalled earlier in the day too which has never happened before. It was 100 degrees here today which I'm sure played a part. I let it sit for ten minutes and then started it back up. No check engine light and it ran ok back to the office. Is the engine on it's way out?
Check plugs, coils, wires, and cat. Hopefully it is just one of those....but since you are still under the warranty, maybe it would be better if your engine did die.
I had a very similar problem and it was the plugs and/or coils, I just replaced them all at the same time and no problems since.
I have an 04 auto, sounds like the same problem
https://www.rx8club.com/series-i-trouble-shooting-95/loss-power-ruff-idle-wiring-short-180170/
I'm hopeing its only the cat
Well I drove it all the way home from work last night and didn't have any problems with it. I added some oil and some coolant before I left work just to make sure everything was topped off. Could it be that it just overheated? Would that cause the check engine light to come on and the loss of power or is it something else?
it will happen again. when my engine acted retarded on me, it ran fine for a couple weeks then it did it again, so I would definitely go ahead and check those plugs and coils to head off the problem. Good luck with it.
The cat would be covered under Mazda warranty. However, he is from Canada and wouldn't receive the US mandated 8/80 emissions warranty.
daddyg, if you are out of warranty, look here for someone selling their used cat. Or, buy a high flow cat from one of the vendors.
Specified major emission control components are covered for the first 8 years or 80,000 miles of vehicle use.
According to federal law, an emission control or emission related
part, or a specified major emission control component, that fails
because of a defect in materials or workmanship, must be repaired or
replaced by the vehicle manufacturer free of charge as long as the
vehicle has not exceeded the warranty time or mileage limitations for
the failed part.
There are three specified major emission control components,
covered for the first 8 years or 80,000 miles of vehicle use on 1995
and newer vehicles:
* Catalytic converters.
* The electronic emissions control unit or computer (ECU).
* The onboard emissions diagnostic device or computer (OBD).
the failed part.
and newer vehicles:
This is for BC. LINK
Motor Vehicle Emissions Control Warranty Regulation, B.C. Reg. 116/96
(a) for specified major emission control components, not less than 8 years or the period within which the warranted vehicle is driven 80 000 miles (128 748 km), whichever is shorter,
I would think the rest of Canada would follow the same guidelines.
a stock CAT cost like 1700 bux.
You can always check your local junk yard to see if there is any CAT there tho. they usually sell it for cheap.
When a ceramic cat "dies", it usually means the coating on the ceramic is gone, then the high temp starts melting the ceramic material so nah there is "nothing" to clean there.
well it did it again and now it's getting towed to the dealership to see what's up with it. had the same thing with the lunging and check engine light and stalling and barely made it to work. i'll keep you posted.
Mine did the same thing last week, and come to find out, 3 coils went bad, which caused 3 plugs to go bad which fried the Rear O2 Sensor. I orderd the parts and put them on this past tuesday, runs good as new.
