Car goes nuts!!
Old Aug 11, 2009 | 01:52 PM
RX8 Knight Rider's Avatar
Car goes nuts!!
When i push the unlock button on the factory alarm my gauges start going crazy back and forth, the car wont start at all, the lights are flickering like crazy and a bunch of other stuff. I have a buddy who told me that it could be the actual alarm that is messing up the rest of the system and i need to reset it. Does anybody know what it could be?
Anything would help to get my baby running again!!
Old Aug 11, 2009 | 01:57 PM
RIWWP's Avatar
KITT is probably just complaining again....
(sorry, couldn't resist)
it's odd, sounds partly like the immobilizer is kicking in, but I've never heard of it reacting like that. It should be just the security light flashing when you try to start it. I don't think the panic button is supposed to affect your gauges either, so I don't think you are refering to that.
What is the reaction if you hit the Lock button and if you hit the panic button? If they all act up, might need a dealer to fix or replace the FOB, as a guess. If it is just unlock acting up...i don't know. Check your battery's charge? Try jumping it? Throwing guesses out there really
Old Aug 11, 2009 | 02:09 PM
it happens if i push any of the buttons.
Old Aug 11, 2009 | 02:18 PM
RIWWP's Avatar
What if you lock, and then unlock the door with the key itself? What happens?
Also, AFTER you check that, try cycling the key in the door lock 3 times (lock, unlock, lock, unlock, lock, unlock) and then the same in the ignition, between ACC and ON. I forget which one, but one of them tries to match the key to the ignition again. Maybe the code got lost from a battery issue?
Let us know.
Old Aug 12, 2009 | 11:09 PM
Bad car battery or connection. Check that out.
Old Aug 13, 2009 | 07:35 AM
Well i tried all of the abobe and it didnt work but now the gauges work fine except for the radio display. It keeps coming on then turning off and when i tried all my light the headlights wont come on but all the rest do. I went to autozone and got the battery checked and its good. I cleaned the terminals but the positive gets really bad with the corrosion.
I cant think of what else to do besides take it to the dealer and pay an arm and a leg for them to just check!
Old Aug 13, 2009 | 07:55 AM
RIWWP's Avatar
It's got me stumped then. The symptoms really seem like a weak battery or starter.
I would recommend posting in the Gulf forum (covers TX), see if there are any 8 owners within driving distance that would be willing to come to you and help you out.
What year/transmission/miles/trim do you have?
Old Aug 13, 2009 | 08:10 AM
I have a 2004, 6speed trans with 62000K and I have the basic trim.
Old Aug 13, 2009 | 08:23 AM
RIWWP's Avatar
Yeah, your only bet other than local help (unless someone that has dealt with it sees this thread), is going to be the dealer, and you are out of warranty
Head down to the Gulf regional forum and see if you can get anyone local to you to assist, there are quite a few people in the Houston area.
Old Aug 13, 2009 | 08:55 AM
Aight. Well thanks for tryin to help homie.
Old Aug 13, 2009 | 10:04 AM
HeavyMetal699's Avatar
I would try battery as well. The summer heat kills them.
I just had mine replaced and my car isn't even 2 years old.
Old Aug 13, 2009 | 10:24 AM
I replaced mine when i first got the car cuz i bought the car used. I checked the one i have now at autozone and the machine said it was good. It cant be the battery though cuz everything comes on its just the car wont start and my headlights wont come on wen i try to turn them on either. Everything else works though. Im just tryin to find someone from the houston area to see if they can come look at it cuz i cant go no where and i really dont want to pay an arm and a leg to get it checked.
Old Aug 13, 2009 | 03:50 PM
I hate to say this but this is probably a dealership item.
My best advice is to get a set fee for troubleshooting when you take it in. Don't let them charge you by the hour to troubleshoot.
Skyl3r
Dec 2, 2019 04:51 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
AussieGray
Jul 16, 2015 03:58 AM
