Loss of power, ruff idle, wiring short
Old Aug 10, 2009 | 06:25 PM
gcrx804's Avatar
I have an 04 auto 50,000 miles, had a loss of power and stalled the other day, restarted and it was fine for the next few days.
2nd time it was a loss of power, ruff idleing but was find after a minute, then 5min later 'Check Engine Light' came on with another loss of power and i pull over checked and had a burnt plastic smell and found a little smoke coming from the trans area. Got it towed home, checked under it and the wiring attached to the trans is melted! Must be a short somewhere.
Engine and trans oils are ok, all gauges were reading normal.
Called around yesterday and no one knows what it could be.
Anyone got an idea? Heard of this problem before?
Old Aug 10, 2009 | 06:37 PM
dozer's Avatar
on his 3rd rx8
hmmmmm maybe a gone cat
Old Aug 10, 2009 | 07:44 PM
gcrx804's Avatar
AU
Just remembered had a small bottom out going over a speed hump 2 weeks ago and there is some dents in the cat.
The blue wire connector is badly melted and when it happened the floor above the cat was really hot, maybe this could have melted the tranie wires.
Can a wiring short come from a faulty cat?
Old Aug 11, 2009 | 12:05 AM
gcrx804's Avatar
Just priced a new cat from the Mazda dealer, A$3100 (around US$2600), are they for real!!
Old Aug 11, 2009 | 08:09 PM
ira1377's Avatar
they are was lucky to get mine under warranty
Old Aug 11, 2009 | 08:10 PM
ira1377's Avatar
might be ignition coils
Old Aug 12, 2009 | 11:04 AM
ODDDOOD's Avatar
The DOOD abides.
If it's your cat...get a hi-flow cat for much less and add a bit of power. The OEM cats are ridiculously overpriced.
Good luck
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
uZu
Dec 30, 2015 12:35 PM
Espo
Aug 11, 2015 07:11 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
