New battery, now car won't idle
Old Aug 10, 2009 | 01:16 PM
renaldo's Avatar
Just as the title says, I just put a brand new battery in and now the car will not idle. It runs fine, but once I let of the gas it dies. Any suggestions before I try to get it into the dealership?
I replaced it with a duralast gold that had the exact same specs as the mazda battery.
Old Aug 10, 2009 | 01:21 PM
Check your MAF make sure its clean.
if its clean then ...
Your engine or Throttle body is bad. Have it check
Old Aug 10, 2009 | 01:23 PM
renaldo's Avatar
It just seems weird that everything was fine until I replaced the battery...
Old Aug 10, 2009 | 01:29 PM
cyclone1208's Avatar
Loose connections maybe?
Old Aug 10, 2009 | 01:33 PM
renaldo's Avatar
I double checked all the connections and I even made sure we didn't knock anything loose.
The new battery wouldn't be the issue would it?
Plus the car is starting fine, I just have to keep my foot on the gas to keep it from stalling.
Old Aug 10, 2009 | 01:42 PM
did this issue happened with your old battery too?
Old Aug 10, 2009 | 01:48 PM
renaldo's Avatar
Nope. Everything was fine with the old battery.
Old Aug 10, 2009 | 01:58 PM
huh...u might want to return this battery and get a new one
Old Aug 10, 2009 | 02:41 PM
renaldo's Avatar
Dealership said it wouldn't be the battery, I just dropped it off. I will let you know what they say. I am sure it will end up being something ridiculously expensive!
Old Aug 10, 2009 | 02:47 PM
Its not the battery, if its the battery his car won't even start.
Most dealership will not check Throttle body so you might want to "give them a hint".
Old Aug 10, 2009 | 02:49 PM
renaldo's Avatar
Ok. Thanks for all the input. Hopefully it won't be anything major.
Old Aug 10, 2009 | 03:01 PM
Worst Case scenario is bad engine. no biggie
Hmm, but if its throttle body ... You're out of luck, the part will cost you like 500 bux
Old Aug 12, 2009 | 11:08 AM
renaldo's Avatar
Turns out the computer lost all of it's memory. Dealership said that they weren't sure why. They had to redownload everything to it. Had to pay for it though since I am at 88k miles.
Old Aug 12, 2009 | 11:41 AM
you got ripped.
If they're talking about the "missing" of LTFT and STFT then yeah of course its gone, you pulled your battery.
If your computer is messed up you will see a CEL of self check failed and your car might not even start.
They gave you a bs excuse so they can charge you an hour of labor for it.
If you changed your coils, plugs, and wires already then I can 99% guarantee you that its either your throttle body, or your engine.
Old Aug 13, 2009 | 03:40 AM
wow,
this is sad.
it takes several drive cycles for the idle to get back to normal..
i would be pissed.
Old Aug 13, 2009 | 03:45 AM
Flashwing's Avatar
3-wheeler
Oh yikes! They made you reflash the whole computer? Did it solve the issue you were having?
In the cases where I had extreme fuel trims with my K&N Typhoon II (like +19% at idle) the car would die at idle when I reset the computer system. It would have to learn the trims before it would be fine for daily driving.
Old Aug 13, 2009 | 04:21 AM
rodjonathan's Avatar
silent assasin
did the issue get solved?
Old Aug 13, 2009 | 08:35 AM
rofl ? 19% ?!
dang.
I never got that when I had K&N install
Old Nov 5, 2009 | 03:01 PM
BAM0027's Avatar
I just changed my battery, figured it was reasonable for an '05, and I am having the same experience as the original post; my car won't idle. I've only started the engine twice since replacing the battery, so maybe things will adjust after a couple more cycles. The car had no power for less than five minutes; it'd be weird to lose essential settings from such a short duration. More later.
Old Nov 5, 2009 | 03:14 PM
What a rip. Lost it's settings? Thats a new one.
Old Nov 5, 2009 | 04:13 PM
BAM0027's Avatar
I just started the car again, third time since the battery installation, and it idles fine now. Weird, but cleared.
Old Nov 5, 2009 | 06:55 PM
I never had any problems when I had my K&N.
Anyway, yeah, he got ripped.
a "healthy" throttle body & Engine will NOT have a hard time idling. so yeah you get the idea.
Old Dec 23, 2009 | 09:56 PM
ELX13's Avatar
CHAH-LAY MURPHAAAAAY!
i haven't been on the forums in a very, very long time but this JUST happened to me today. the car will be sitting for a week while i'm out of town for christmas. i hope it goes back to normal after a few more starts. i had to start the car at least 6 times while driving back home after replacing the battery.
Old Dec 27, 2009 | 04:40 AM
bgreene's Avatar
Time of your life, kid...
Same thing happened to me a few months ago. Dealer said the car went into "relearn" mode and that it's normal (or at least it's known to happen" when the battery is disconnected. Basically you have to live with it for a couple sessions/days and the computer will figure it out again on its own.
Seems screwy, but it'll pass. Took my car 2 days to quit stalling and another day to find a good idle. Might speed things up to let it "idle hunt" (sit in neutral wile the revs vary from near-stall to almost 2k) for a minute or two.
Old Aug 20, 2013 | 05:06 PM
Silverdollar's Avatar
What is an MAF ? Thx
Jesus Martinez
44
May 6, 2025 08:09 AM
Wantingtoknow
Dec 15, 2016 02:25 PM
harithac
Jul 25, 2015 04:21 PM
T_Mags
Jul 24, 2015 11:29 AM
Kangarhew
Jul 18, 2015 08:27 PM
