Help?
Old Aug 9, 2009 | 11:23 PM
winningblu4u's Avatar
Help?
Today, I was leaving a friends house when my car suddenly stopped. I was in the driveway and when I was getting ready to leave the car just shut off. My friend tried to give me a jump but it would not turn on. I then got my friends brother to come and bring his car(Mazda 3) to get a jump and then the car worked. I recently replaced the battery about a month ago so I am sure it has to be something other than the battery. Also, for the past couple days while I have been driving, the radio will turn off and then turn back on, while this happens the DSC light comes on. Has anyone had any similar problems like this or does anyone have any input with what is going on. Thanks.
Old Aug 9, 2009 | 11:25 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Car under warranty?
Old Aug 9, 2009 | 11:38 PM
warranty went out a couple months ago
Old Aug 10, 2009 | 12:11 AM
I8U's Avatar
I8U
Check to make sure your battery connections are good. I've seen what you are talking about due to the battery cables not being tightened down all the way.
Old Aug 10, 2009 | 12:22 AM
sxe1215's Avatar
ghosts...
Old Aug 10, 2009 | 12:57 AM
Easy_E1's Avatar
Check the battery terminals/connections. Make sure they are clean and tight.
Old Aug 10, 2009 | 06:33 AM
DarthRX8's Avatar
Force User
^^ If they are dirty and have white **** all over them use baking soda to clean them off and tighten them back down.
Old Aug 10, 2009 | 06:53 AM
rotarykillz's Avatar
Rotary Freak
yep definitely sounds like battery connection...esp with your DSC light coming on. Keep an eye out for your presets resetting too.
Old Aug 10, 2009 | 07:27 AM
mulkio's Avatar
Under-prepared
+1 for battery terminal connections, same problems 6 months ago.
Old Aug 10, 2009 | 10:07 AM
Thanks for the help
Old Aug 10, 2009 | 01:14 PM
04RX8man's Avatar
Rotary Powered Countryboy
also wouldn't hurt to get the alternator check while you're at it
