New engine care? Need some info
Old Aug 8, 2009 | 12:01 PM
wyldechild's Avatar
Hey guys, once again back for some helpful info. I did search for this; but, nothing of the sort popped up.
Basically, I just had a new engine put in by the local dealer, which is a whole other story, and I would like to know the correct procedures and driving habits to make sure this one will last. Or at least not have it break down due to my unproper care. Just let me know whats up and it will be greatly appreciated. Thanks again 8 owners.
Old Aug 8, 2009 | 12:06 PM
dozer's Avatar
on his 3rd rx8
dont redline or drive too hard the first 1k miles...then the normal maintenance, oil changes, spark plugs and coils....
Old Aug 8, 2009 | 12:10 PM
wyldechild's Avatar
at what RPM's should I be shifting at about? like don't push it past 6k or?
Old Aug 8, 2009 | 08:13 PM
04RX8man's Avatar
Rotary Powered Countryboy
^don't go past 6k for sure until it gets broken in a bit....also premix will help save your motor also!
Old Aug 9, 2009 | 10:27 AM
Pico's Avatar
It's Complicated
This link should tell you everything that you should know. Click on the "How to break in your RX8" button
http://www.racingbeat.com/FRmazda4.htm
Old Aug 9, 2009 | 01:21 PM
wyldechild's Avatar
Thanks Pico, is that everything?
Old Aug 9, 2009 | 02:58 PM
Pico's Avatar
It's Complicated
Basically that's the important things to remember for the brake in period. Normal maintains is important for powertrain longevity. Now, choosing the right oil HaHa that's a different story all together . You do a search on that and you can figure out what weigh and type is right for you.
Its simple: brake the motor in properly, after brake in drive the car the way it meant to be driven- don't be afraid of redlining _it will keep your motor happy and the carbon away. Normal maintenance is a MUST with this car don't avoid checking, filling, flushing, or replacing any component. You'll pay later
You have a fresh start with a new motor, I think there's a lot of people here that would love to be in your shoes. So, be on PAR, search to boards if you have a problem- odds are you'll find the info, and just drive drive drive.
Old Aug 9, 2009 | 03:35 PM
04RX8man's Avatar
I(as many others) suggest using 5w30 or higher weight and premix.....i'm hoping my motor goes out at 99,999 miles as I roll into the dealership!!!!
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Dokuji
Nov 1, 2016 02:51 PM
Sifu
Aug 30, 2015 10:51 PM
