Aux Port?
Old Aug 7, 2009 | 07:33 PM
eduncks's Avatar
Aux Port?
hey guys. i just bought my 2004 rx8 and it doesn't have an aux port. i've seen that you can buy one. but is it better to go through mazda to get one or aftermarket stuff? can anyone recommend a good and easy to install one?
Old Aug 7, 2009 | 08:50 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Search, you got more than one option.
Old Aug 7, 2009 | 11:01 PM
ZachLegend's Avatar
Are we talking an integration kit or an actual AUX port? I haven't seen anything about an AUX port, i searched.
Old Aug 7, 2009 | 11:38 PM
rodjonathan's Avatar
silent assasin
^ im pretty sure most of the intergration kits have an aux in too ... not 100% sure but 99% at least
Old Aug 7, 2009 | 11:53 PM
ZachLegend's Avatar
i thought the integration kit was just something you plugged in the back of your stock head unit.
Old Aug 8, 2009 | 12:36 AM
silent assasin
yea but it has a box with it that has a usb port and an aux IF im not mistaken
Old Aug 8, 2009 | 02:38 PM
eduncks's Avatar
Ya I've seen some that plug into the back.
Old Aug 8, 2009 | 07:14 PM
eduncks's Avatar
http://www.adleraudio.com/web/mdl/XA120IP/detail.asp
will this work guys? it says its compatible with my 2004 rx8 but is it good? anyone try it before?
Old Aug 10, 2009 | 02:22 PM
mbentley's Avatar
zoom-zoom
it will work great if you have a sony stereo installed in your car...
many people suggest either:
http://www.therpmstore.com/product_i...roducts_id=141
or
if you have an ipod:
http://www.therpmstore.com/product_i...roducts_id=142
i plan on getting the first one myself because i just want an aux port.
Old Aug 10, 2009 | 08:22 PM
eduncks's Avatar
Will it work with a stock Bose sound system? Or only with a Sony?
Old Aug 10, 2009 | 09:27 PM
ZachLegend's Avatar
gees getting an AUX port is just as expensive as the intregration kit.
Old Aug 11, 2009 | 12:26 AM
Z0oMzo0m's Avatar
You can search GROM i just ordered mine to hook up carpc. Its 60 bucks on EBAY or 70 from a website. pick your choice
Old Aug 11, 2009 | 08:12 AM
mbentley's Avatar
zoom-zoom
only with an aftermarket sony stereo.
Old Aug 11, 2009 | 03:54 PM
eduncks's Avatar
the grom looks good. but is it a aux port or a fm conveter?
Old Aug 12, 2009 | 11:19 PM
ZachLegend's Avatar
The GROM thing seems to be an AUX port. FM transmitters go through your radio, obviously, and plug into your cig lighter.
This GROM thing goes through your CD changer cable and runs through the AUX port. So I'd assume you'd hold the ipod instead of doing Radio controls, which I feel would be a bitch. I'd rather control it through the Ipod. That would be amazing, and $60 is dirt cheap for that. Anyone that has this GROM thing, how does it sound? CD quality?
Old Aug 12, 2009 | 11:36 PM
Z0oMzo0m's Avatar
im using it to hook up the carpc. it will "give me another aux. unit on my controls". il be able to change mode through my steering wheel controls or using the dash itself. at least thats the way i read it will work.
Old Aug 12, 2009 | 11:43 PM
hakuna matata!
aux port is just that, an auxiliary port that has a interface mated to your stock HU.. unless you want steering wheels controls for your iPod or charging an integration kit is useless.
sound quality will be the same.
get a grom for $62 shipped from indashpc.org and you can plug in anything with a standard 3.5mm audio jack and get sound.............. if that's all you wanted.
Old Aug 13, 2009 | 03:29 AM
ZachLegend's Avatar
That is all I want. So just buy it and plug it into the back of the stock head unit and run it through and then you have sound?
Old Aug 17, 2009 | 08:04 AM
eduncks's Avatar
i have firmware version 9.53 so groms wont work with my hu. do i need to get a firmware upgrade or is there some other way to play my ipod through my radio?
Old Aug 17, 2009 | 08:01 PM
ddtran46's Avatar
Yeah..I have the same problem as you too. I think you do have to get a firmware upgrade, but I think that I've read that someone has used it fine without the firmware upgrade.
Old Aug 17, 2009 | 08:48 PM
Z0oMzo0m's Avatar
http://www.whatsmyip.org/ipodrx8/
You can always try this..
Old Aug 18, 2009 | 10:24 PM
ZachLegend's Avatar
Haha, i'd rather not.
Old Aug 18, 2009 | 10:55 PM
ddtran46's Avatar
Haha. Same here..when he showed that link, I was like "F@*k that"
Old Aug 18, 2009 | 11:21 PM
Wheels, not rims!!
I did it but instead of hacking things apart and having a ridiculous wire stick out. I did a clean install of a 1/8" female stereo jack. Looks no different from OEM AUX jacks. Sounds clear also. Took me a while to find a program to create the silence CD though.
Old Aug 19, 2009 | 12:53 AM
tttp5's Avatar
how do i get a firmware upgrade to get the GROM to work?
