No Power
Old Aug 5, 2009 | 12:28 PM
Grayzee's Avatar
No Power
I'm having engine issues, it starts ok then just before it get up to full temp there's no power and it sounds really rough and it's difficult to keep noving. Eventually it clears itself and runs fine but there's white deposits in the exhaust now instead of the usual black. Any ideas or is it an expensive visit to the dealer?
Old Aug 5, 2009 | 12:47 PM
You suppose to warm up the car other wise the ECU limits power.
If exhaust is looking white... it is running leaner.
What year is car? Last tune up?
Old Aug 6, 2009 | 01:59 AM
Grayzee's Avatar
2004 and it was serviced about 10 months ago. It's not the ECU limiting power, if it had a normal engine i'd say it was only running on two cylinders.
Old Aug 6, 2009 | 05:36 AM
Is your coolant level stable.....or dropping?
Old Aug 6, 2009 | 12:45 PM
Grayzee's Avatar
I haven't checked but I will tomorrow. It's odd, it was fine this morning then driving home the engine warning light came on and for 3-4 mins it just wont go, I had trouble tryin to overtake some bicycles then suddenly it surges and it's ok for a while then it starts all over again then nothing for a while
Old Aug 6, 2009 | 12:53 PM
ODDDOOD's Avatar
The DOOD abides.
Seems I always post this but I'll throw this out there...
catalytic converter
Have it checked. If you've ever had any flooding events, this is very likely to be melted/clogged.
Also, check your spark-plugs, wires, and ignition coils...as per the usual.
I bet it is one of those things.
BTW...you should also get the Check Engine Light (CEL) code read if you have not already...this can sometimes pin-point your issue. Once you get that read, post up what you find. Any store like pep-boys, autozone, car-quest, etc...can do this for you.
Good luck
Old Aug 15, 2009 | 10:59 AM
Grayzee's Avatar
Ok now I'm really confused.
I got a new coil and removed all the old ones but it wasn't that obvious which one had gone. One did look a little white so I replaced it and put everything back together. I thought if it wasn't that one then I would just repeat the process until I found the faulty one.
First time I tried to start it the battery which was pretty low before was now flat. I got a jump start from a friend but the engine just keeps turning over and not catching. It sounds like none of the plugs are firing.
I took it all apart and checked the lead were on the rightway round and that all the connectors were pushed in place and tried again and it just turns over and over.
What am I missing? I really can't understand please help!
Old Aug 15, 2009 | 11:28 AM
rx8james89's Avatar
silver rx8
It does sound like the cat has gone I had a similar problem with having no power then having little surges of power got the cat replaced and it was fine take it to a garage and get them have a look.
Old Aug 15, 2009 | 11:37 AM
Easy_E1's Avatar
If you have white in your exhaust tips that means that the exhaust temps have been VERY HIGH!
That would indicate a clogged/restricted Catalytic Converter.
Either that or you've been running the car at track speeds on city streets.
Old Aug 16, 2009 | 12:56 AM
04RX8man's Avatar
Rotary Powered Countryboy
looking at the cat after a drive(for glowing red) could indicate a clogged cat too!
Old Aug 16, 2009 | 02:40 AM
Grayzee's Avatar
So if the cat is the issue that means the car wont even start?
And it's not so much surges of power it was that it wasn't running properly then it surged when it started firing on both rotors again.
Old Aug 16, 2009 | 03:26 PM
shaunv74's Avatar
Power!!
The cat. would not prevent your car from starting but it can cause other problems that could lead to that if it's not addressed. your cat. should have a warranty still as well as your engine core. Bring it in to the dealer to have it diagnosed. They'll be able to check to see if you have bad coils, plugs, or cat etc. Have you read the code yet?
If not you're just guessing when the car is trying to tell you what's wrong.
Old Aug 17, 2009 | 12:30 PM
Grayzee's Avatar
There's nowhere near me in the uk where I can get the code read plus as it now wont start I don't have a chance. Thing is it sounds like coils. I't had been a little hesitant for while but not much, then it got worse like it was only running on 1 rotor so I took all the coils out and checked them, now it wont start.
Thanks for your help but I guess I just need to get it towed to a garage.
Old Aug 18, 2009 | 08:37 AM
ODDDOOD's Avatar
The DOOD abides.
If you have a jack and stands, you can pull the cat yourself and at least check it out.
There are some tough bolts to get undone, but in the end, you should be able to get it out.
Once out, you can inspect it to see if it is indeed clogged/melted. The description on my transaction from the dealer stated the cat. was "obliterated". You could also try and start it with the cat off...warning, it will be super loud and awesome. I don't recommend driving on it like that, but it might help diagnose the problem.
Good luck...you could also order a hi-flow cat. for replacement or even a mid-pipe (test-pipe).
Shankapotamus3
Mar 14, 2021 03:53 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
D13
Oct 1, 2015 07:55 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
