Power Loss Indeed
Old Aug 4, 2009 | 11:51 PM
ambitionz's Avatar
NY Power Loss Indeed
i have a 2004 automatic
rx8 just about to hit 60,000 miles
and as the title says i felt a power loss
i did a few changes which are:
-Ignition Coil (one of them were bad)
-Moroso Spark Plug Wires
-NGK Spark Plugs
and i am still feeling the power loss...
any ideas? thanks, nathaniel
Old Aug 4, 2009 | 11:52 PM
Spinning Sushi's Avatar
I <3 Sushi
Define this power loss.
When does it occur? What RPM's?
You might have a clogged cat or need a new engine.
Check your cat. Do a compression test.
Old Aug 5, 2009 | 12:06 AM
ambitionz's Avatar
m not sure exactly what RPM's
i'll let you know tomm, my 8
is sounding like a beat up civic when i
step on the gas...clogged cat?
thanks for the advice
Old Aug 5, 2009 | 12:07 AM
I <3 Sushi
Sounds like a beat up Civic? I'd totally go and check your cat to see if it's destroyed before it leads to a catastrophic engine failure.
Old Aug 5, 2009 | 12:11 AM
ambitionz's Avatar
cat? sorry for being a newbie
Old Aug 5, 2009 | 12:13 AM
I <3 Sushi
This is a cat:
In the car world, a cat (catalytic converter) is known as this:
It's right behind your exhaust manifold. I would remove the cat and check it to see if it's fubar'd.
Old Aug 5, 2009 | 12:15 AM
ambitionz's Avatar
google <3
thanks for your help means a lot
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Trekk
12
Sep 25, 2015 03:08 PM
Draken
Sep 21, 2015 06:14 PM
