HELP car wont start
Old Aug 3, 2009 | 11:35 AM
Twiztog43's Avatar
CA HELP car wont start
i know its not flooded because the last time i drove it was an hour drive
anyways i was trying to crank it this morning but it just would not budge
i know the battery is not dead because the radio works and i tried jump starting it and it would not start either.
i have an 05 MT
Old Aug 3, 2009 | 11:38 AM
laythor's Avatar
I zoom therefore I am.
have you checked the starter?
Old Aug 3, 2009 | 11:42 AM
Twiztog43's Avatar
how would i do that? [noob]
Old Aug 3, 2009 | 11:46 AM
laythor's Avatar
https://www.rx8club.com/series-i-tech-garage-22/problem-starter-137214/
check the tsb, you might just need a new starter from the dealer.
Old Aug 3, 2009 | 12:04 PM
CyberPitz's Avatar
Huge hole is huge
So, when you turn the key, the motor doesn't move? Then it's probably the Starter.
Old Aug 3, 2009 | 12:19 PM
alfy28's Avatar
i had the same situation as you 3 weeks ago. while driving, my car just died on me. pushed the car to to shoulder, tried starting it up. No luck.
Radio , dash console showed up also. Had someone jump my car, drove the car down the street, and it died again. So pushed the car to shoulder again. Popped the hood, felt if the my alternator was cold, it wasn’t. taken the battery out and walked a mile or so to autozone, had them tested my battery. Showed up that my battery was dead. Popped a new one in, started up. Had my alternator tested and starter checked, showed its still good. So maybe you should have your battery checked also. even though my starter showed good, i like to change out things at the same time. so changed out my starter this passweekend.
Old Aug 3, 2009 | 12:33 PM
Twiztog43's Avatar
i know its my starter because its not the battery, my battery is fine, because the radio works, lights ect.
when i try to start it, at first it would try to crank, now its just "click click click"
my engine is definitely not flooded because i dont turn on my car to move it, i usually drive a minimum of 20 miles a day so im pretty sure thats out of the question
Old Aug 3, 2009 | 12:37 PM
alfy28's Avatar
well the same was for me. my radio , lights worked. just my car wouldlnt crank, also car made click noise c after a few tries trying to start the car .
i am just saying, have your battery checked also. because it was my battery that was at fault, when i was cursing at my starter. . but hey , its your car, i was just sharing the example i had 3 weeks ago. also starter showed perfect when i had them test it at mazda. i just changed it out, because i like starters and battery changed close to the same time. any how gl to you.
Old Aug 3, 2009 | 12:42 PM
Twiztog43's Avatar
well i just had a friend come over [just left, errands] and we tried jump starting it..... still nothing!
Old Aug 3, 2009 | 01:21 PM
DubbsLuvs8s's Avatar
Sounds like the starter...if you can't jump it, then it's not the battery (not ONLY the battery I should say) Is it manual? Try a bump start?
Old Aug 3, 2009 | 01:53 PM
alfy28's Avatar
but teh same can be said about a bad battery. i had to wait 15mins before i can even get my car started with a jump. . because the first 3 tries wouldnt work. so the person in the truck was nice of enough to let the jumper cables stayed connected for 15mins, so that i can get a charge, then iw as able to crank it. any ways, best to get both checked, but that is just me. any how gl tc, ih ope your problem gets resolved.
Old Aug 3, 2009 | 02:53 PM
map's Avatar
map
Sounds like battery to me. Just because you can run the radio doesn't mean it has enough power to start the car. First it cranked and now it's clicking means you used the little juice it had left. But then a jump should work... still, I'm going with battery.
Old Aug 3, 2009 | 02:59 PM
thats a dead battery.
Old Aug 3, 2009 | 03:17 PM
EDZRIDE's Avatar
2005 White GT
"click click click" is the first indication of a weak battery.
Old Aug 3, 2009 | 03:36 PM
Twiztog43's Avatar
Thanks for the help guys!
I'm at the dealership now!
On a side note, there are a lot of rx8's here for some kind of repair
I have seen 5 including mine in the last hour!
Old Aug 3, 2009 | 03:57 PM
Twiztog43's Avatar
Hey just got back to me and it is a dead battery which is $105
they also suggested new airfilter $49 (I'll do it myself)
and cleaning the throttle body (carbon buildup) $149
does this sound reasonable?
Old Aug 3, 2009 | 04:00 PM
alfy28's Avatar
cool, glad your problem has been resolved. as for the carbon buildup, there is a DIY here in the DIY section. which probably only cost you about 30 bucks.
Old Aug 3, 2009 | 04:03 PM
If TB is the cleaner they put in the ports per TSB do it!
I ist an additive to gas or spraying of the TB do it your self.
Ask a few questions then deceide.
Old Aug 3, 2009 | 04:04 PM
Twiztog43's Avatar
Well I'm already here, plus it would depend on how much mechanical experience one would need in order to do that diy
Old Aug 3, 2009 | 04:05 PM
cjkim's Avatar
^noob
$149 to clean throttle body?
20 minutes and a $4 can of tb cleaner
DIY
Old Aug 3, 2009 | 04:13 PM
Twiztog43's Avatar
Damn too late
Old Aug 3, 2009 | 04:17 PM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
my throttle body was only $80 at the dealership. huh
Old Aug 4, 2009 | 02:08 AM
AJ's Shinka's Avatar
Enthusiast
damn $150 FOR TB CLEANING!
Old Aug 4, 2009 | 04:18 PM
YaXMaNGTO's Avatar
It's a Cavalier
Yah, you just learned a couple valuable lessons, and like most newbs, you had to pay for them in cash.
It was obviously a bad battery, and you could have bought one and changed it yourself for $60 instead of whatever you ended up paying.
But, luckily, you didn't get didn't get taken for a BIG ride. If you got out for two or three hundred dollars, forget it, and do better next time.
Old Sep 1, 2009 | 04:21 PM
Myardor's Avatar
just replaced my battery
total cost?
at wally world
75 plus tax plus 3 state battery fee
did the re placing my self
battery was dead, some cells did not even have water
