View Full Version : WANTED Passenger side tail light assembly
dirtyd
08-03-2009, 12:12 PM
does anyone have one that in good condition?
desouza.darryl@gmail.com
PaQuiN
08-03-2009, 01:36 PM
I need one too. Why do you need one? If your getting moisture build up in it you can buy a gasket to fix that at a Mazda dealer. There not cheap, about 30 bucks a side.
I need one because I was too cheap to buy the gasket so I punched a hole in the bottom of the light to drain it. Believe it or not this trick worked pretty good. However...I broke a retainer clip taking it out and putting it back in so many times, lol...good ol silicone should hold it for a bit.
dirtyd
08-03-2009, 07:26 PM
i dried the moisture with a hair dryer for the second time and re-seal it with more silicone, after I re-installed it i noticed that i put too much heat to it and now there is alot of cracks all over the lens
dirtyd
08-05-2009, 09:32 PM
now I also need a window motor driver side
rx8shift
08-09-2009, 09:52 PM
hahaha I also dried mine too much with the hair dryer causing damage, the plastic actually melted on the inside of the tail light and the bulb will not go back in all the way.
