Rotary Diesel?
Old Aug 3, 2009 | 09:53 AM
rx8it's Avatar
Rotary Diesel?
I wonder how feasible would it be for Mazda to build a diesel rotary. Have they tried in the past? Is it even possible?
Old Aug 3, 2009 | 10:03 AM
Huey52's Avatar
Registered Zoom Zoomer
It's certainly possible but requires a much higher compression ratio which brings its own strength of materials issues and historically therefore added weight to diesels. Good advances in the common rail diesel design tho' btw.
Old Aug 3, 2009 | 02:27 PM
RufusVonStorm's Avatar
Paging RotaryGod
I don't think you could get enough compression on a rotary to ignite diesel
Old Aug 3, 2009 | 02:43 PM
8 Maniac's Avatar
Senior Member
It would be cool to see, but I doubt it will happen.
Old Aug 3, 2009 | 02:48 PM
rev8's Avatar
so it's a V twin?
mercedes benz already made one. many car manufactures have made wankles in the past. i read a book at the library a while ago it had the whole history of all the players that have played with the wankle.
Old Aug 3, 2009 | 02:49 PM
olddragger's Avatar
spark assisted diesel has already been done on our engine. Pettit did it.
wasnt worth persuing.
OD
Old Aug 3, 2009 | 02:50 PM
rev8's Avatar
so it's a V twin?
found it http://www.conceptcarz.com/vehicle/z...enz-C-111.aspx
Old Aug 3, 2009 | 03:33 PM
rotarygod's Avatar
Originally Posted by RufusVonStorm
Paging RotaryGod
Correct. Since we have to flow and compress air as opposed to just compressing it, that means as the compression rises, flow decreases. If we get compresion too high, flow is too low and now we have huge pumping losses. The compression limit on a rotary is around 11:1 or so which is too low for compression ignition. You can use spark ignition for a diesel though and this has been done before on rotaries. You obviously don't have the power that you would with higher compression and due to the nature of diesel flame front speed, you also don't get the high rpm use that a rotary is so good at. It's really best in a low speed application but due to the compression ratio and low displacement, you just can't get much power from a diesel rotary.
You could potentially get compression ignition through the use of a positive displacement supercharger such as a roots or twin screw. This would raise the effective compression ratio to a higher level. However at lower speeds you'd still need a spark or glow plug system. I would think that due to the lower power output of a smaller engine such as a rotary with lower rpm limits that they'd be best for use as generators or apu's.
Old Aug 3, 2009 | 03:34 PM
neXib's Avatar
I shiver at the thought.
Old Aug 3, 2009 | 04:01 PM
And that doesn't include all the members here that play with their wankel.
Old Aug 3, 2009 | 10:01 PM
rev8's Avatar
so it's a V twin?
is it bad to play with my wankle^ the benz looks like the deloran almost.
Old Aug 3, 2009 | 10:22 PM
2SeeKU's Avatar
Aussie
You just had to go there didn't you!
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
JCTaylor
Sep 30, 2015 07:31 PM
