installing agency power under drive pully
Old Aug 2, 2009 | 04:34 PM
cory_mcm's Avatar
Hey guys was just trying your do it your self thread for the agency power pulley kit and i need some help with taking my crank pulley off. Ive got all the bolts and belts off but there seems to be somthing alse holding it on there, was just wondering whats the best way to get it off. Thanks i kinda need the car so i hope some one posts soon lol
Old Aug 2, 2009 | 04:39 PM
Jon316G's Avatar
Grasshopper
Once the 4 bolts are removed, nothing else is holding the pulley on except dirt & grit.
Now comes the time where you curse and pry at it without damaging the positioning plate behind it (the plate with the teeth).
It took me a while to get my pulley off when I did mine.
Just carefully move around the pulley prying at it.
Old Aug 2, 2009 | 05:01 PM
pgrothe's Avatar
I had the same issue. Someone suggested me to use a 2x4 and a hammer to knock the old pulley out of the place. The 2x4 will not damage anything since it'S wood and it's smooth.
It worked great for me and the pulley got out of the way very easily and quickly.
Old Aug 2, 2009 | 05:03 PM
Jon316G's Avatar
Grasshopper
^+1
Now that I think about it, I did use a small piece of wood and a hammer to break it free.
I still had to pry to get it off, but I'm sure the wood helped out a lot.
Old Aug 2, 2009 | 05:40 PM
cory_mcm's Avatar
Ya after a few min i took out the old #1 tool (hammer) and gave her a few soft kiss and the first pully fell off so it was no prob from there, i think in about 5 min ill have the belts all tight and the bolts all good. Cant wait to try it out. thanks for posting
Old Aug 2, 2009 | 05:41 PM
Jon316G's Avatar
Grasshopper
Remember to reset the PCM or else you'll get a flashing CEL.
1) Turn the key to the 'ON' position.
2) Rapidly press the brake pedal until you see the oil pressure gauge needle move to the half way mark and back down.
3) Turn the key to the 'OFF' position.
4) Start the car!
Old Aug 2, 2009 | 09:16 PM
shazy's Avatar
I'll only consider buying and actually using those pulleys if they were 50$. But I didn't think it would be that easy to change them.
Old Aug 2, 2009 | 11:15 PM
cory_mcm's Avatar
Great thanks for telling me to reset the pcm i was wondering what that flashing was. I am very impressed with the new crank pulley it just gets up and goes way faster now. I would have to recomend one for everyone with a rx8.
Old Aug 3, 2009 | 12:33 AM
2SeeKU's Avatar
Aussie
Could be the result of simply resetting the PCM.
I cleaned the throttle body out on the weekend and reset the pcm, deffinately feel an improvement.
Old Aug 3, 2009 | 10:19 PM
cory_mcm's Avatar
I seem to have my check engine light flashing even after i reset the pcm twice. So I checked if my coils, spark plug wires and spark plugs are tight and they seem all good and i also did a search on the fourms and it all says the same thing. Just wondering if any one have any ideas it wasnt flashing before i installed the pulley.
Billy Marcial
Mar 1, 2018 06:50 AM
Ajmurphy85
Jul 30, 2015 07:51 AM
iSki123
Jul 27, 2015 12:41 PM
AussieGray
Jul 16, 2015 03:58 AM
