Sirius Question
Searching for an RX-8....
Sirius Question
Hey guys.
I'm looking at buying a 2005 RX8 with SAT ready head unit (head unit has SAT button).
What else needs to be installed to get sirius in the car?
How much would it cost to have a dealer do it?
Thanks.
Kevin
Thanks.
Kevin
You would need the sat tuner, antenna, and have someone install it.
I think the tuner is like $300. Not sure on the install. You may be able to get a tuner online for less and find a specialist to install it. May be cheaper than a dealer.
its do able because when i bought mine it came with sirius on it with an external tuner that use the fm stations. Not sure how much all that costs. And i dont really use it either.
The tuner (typically installed in the trunk) and the antenna (typically installed on the trunk lid).
Get an auto-radio installer to do it. I would think cheaper install and better deal on components. The toughest part is the cable install from trunk to head unit (typically fore-aft console passage).
The Former PSNTLSS
man lucky you guys with the sat button
i cut open my ashtray and put my sportster 5 in there. with the fm switch from sirius (switches from cars antenna to the fm transmitter from sirius(so you dont have to find a station it blocks the other station out)
Does anyone know where the antenna connects to the head unit? I need to replace my antenna but the wiring kind of disappears in the side of the trunk. I would rather not blindly take out the carpet to find it.
The SAT tuner is in the trunk, drivers side, behind the carpet...it will be zip tied to some braces. From there, that unit connects to the HU (assuming they followed manufacturer recommendations) via a cable that runs under the rear seat, all the way along the side into the dash to the back of the head unit. When I installed mine, we ran that cable thru the center console to the trunk. You will have to remove the HU (which means removing the glove box as well) to get the cable plugged in. Running down the center console was not that tough, we just took it apart, made sure it was well run and not in the way, and I've had no problems for 2 years. as far as the Sirius unit - I'd check the for sale section here - I bought mine used for like $150.
nferguson88
Oct 6, 2015 12:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
