rear shocks... wtf do i do?
Old Jul 25, 2009 | 08:19 PM
rotary boy's Avatar
myspace.com/kustal
Question rear shocks... wtf do i do?
i'm trying to yank the rear shocks out, but i have a feeling i'll have to disconnect some control arms/sway bars/tie rods to get them out... please let me know if there is an easier way to get them out
Old Jul 25, 2009 | 08:26 PM
shaunv74's Avatar
Power!!
There is a DIY for replacing the shocks. You have to take off the lower control arm and sway bar endlink then they drop out. No big deal. You'll need to get the car aligned afterwards which is a good idea anyway.
don't forget the headlight leveler as well!
Old Jul 26, 2009 | 08:47 AM
rotary boy's Avatar
myspace.com/kustal
thank you very much!
Old Jul 26, 2009 | 01:24 PM
rotary boy's Avatar
myspace.com/kustal
Question
now before i get stuck, is there anything i should know about the front ones???
Old Jul 26, 2009 | 01:26 PM
read the DIY
Old Jul 26, 2009 | 01:33 PM
rodjonathan's Avatar
silent assasin
basically same stuff as the rear and read the diy its better too be prepared when going in to change em out
Old Jul 26, 2009 | 01:35 PM
TopGear8's Avatar
mkuhnracing.com
Front ones are easy, Take out the 3, 17mm bolts and the 14mm end link bolt down below. Then take out the 3 14mm bolts in the engine bay, and it will fall right out.
Old Jul 27, 2009 | 12:47 AM
rotary boy's Avatar
myspace.com/kustal
those f'ers are a pain to get out... it seems like i'm wasting my time with the springs i'm trying to put on
Old Jul 27, 2009 | 12:49 AM
I8U's Avatar
I8U
Damn, man you still working on them? Took me a couple hrs to do the whole set, front and rears.
Old Jul 27, 2009 | 12:52 AM
Highway8's Avatar
Registered RX8 Nut
My first time I thought the same thing but really they are very easy once you realize how to do it. If I had noticed you were in sacramento before you took it apart, I would have offered for you to drive to fairfield and I would have helped you. I can change all 4 in about 2 hours with a helper or 3 hours by myself.
Old Jul 27, 2009 | 01:14 AM
shaunv74's Avatar
Power!!
Search the DIY section and read. it's all there for you.
Old Jul 27, 2009 | 01:42 AM
Highway8's Avatar
Registered RX8 Nut
Personaly, I dont do things exactly like the DIY, I disconnect the control arm from the hub and just work the strut out moving the hub and control arm as needed. My way keeps me from having to do an alignment.
Old Jul 27, 2009 | 01:46 AM
shaunv74's Avatar
Power!!
That's fine but it you're asking for help the best help will be form the DIYs that the rest of us have used and commented in. They're very good and cover details many of us will not remember to re-gurgitate for him.
That's why I am saying take a look at the DIY to get the best information and post questions.
Old Jul 27, 2009 | 02:10 AM
rotary boy's Avatar
myspace.com/kustal
i'll give it a try... thanks you guys
Digitz0070
Oct 7, 2015 12:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
