Rear Main Seal Leak
Old Jul 22, 2009 | 08:49 AM
Guisslapp's Avatar
Rear Main Seal Leak
Anyone know if this is covered under the extended engine warranty? Thanks
Old Jul 22, 2009 | 09:51 AM
expo1's Avatar
He's as bad as Can
If you are referring to the 8yr / 100,000 extended warranty I am going to guess no. Mazda specifically covers 'Internal Seals' under this warranty. That would mean that there are some external seals in the engine they do not cover? Can the Rear Main seal be considered an external seal? If your not covered there is a shop located near you that I purchased my rebuilt engine from. Mazmart is the place to get one if you have to pay for an engine out of pocket. Also consider a new clutch & flywheel since your pulling the trans off anyway. If you haven't been to a dealer yet go and mention poor performance and the leak. Request a compression test and there is a chance it could fail which would = a replacement motor.
Old Jul 22, 2009 | 10:15 AM
Guisslapp's Avatar
Thanks for the input. I am actually on my 2nd motor already. Got the new one less than 1 year and 4,000 miles ago. I think you are probably right about the engine core warranty. What makes a seal "external"? The rear main seal is between the rear housing and the flywheel, right?
I am outside of my general warranty, but still have my powertrain warranty. Plus, I should have a 12 month/ 12k mile warranty for the components swapped with the new engine.
Old Jul 22, 2009 | 10:21 AM
the only way to be sure is bring it in and ask.
Old Jul 22, 2009 | 10:25 AM
Easy_E1's Avatar
Call the dealer or show up at the dealer and inquire.\
It shouldn't be leaking after 4000 miles.
Old Jul 22, 2009 | 11:19 AM
Guisslapp's Avatar
To update - the dealer claims that it is not covered under the extended engine core warranty. Still waiting to find out if they will cover it under powertrain or replacement part warranties.
Old Jul 22, 2009 | 11:32 AM
Guisslapp's Avatar
That raises another point. Any idea what could make this seal go bad? Heat or problem with an e-shaft bearing?
Old Jul 22, 2009 | 12:14 PM
expo1's Avatar
He's as bad as Can
A mistake made during the rebuild of your 2nd engine?
Old Aug 26, 2009 | 02:12 PM
Guisslapp's Avatar
Update - I was told that one of the e-shaft bearings was defective (bent?).
Old Aug 26, 2009 | 02:55 PM
Easy_E1's Avatar
Orly! What E-Shaft Bearing? The only bearing is in the rear stationary gear. That's a Babbit Bearing. It's not even close to the seal. OK about an inch away. And the flywheel is what slides into the seal in that area.
Where did they come up with this conclusion?
I call shenanigans!
Old Aug 26, 2009 | 03:21 PM
Guisslapp's Avatar
I call shenanigans!
He said something about it being part of a counterweight. Does that help?
Old Aug 26, 2009 | 03:39 PM
Easy_E1's Avatar
You have a manual Transmission. There is no counter weight unless you have an aftermarket light weight flywheel. He is referring to the sealing surface on the back of the flywheel. The part where it bolts to the eccentric shaft. It has the sealing surface on it. And this is where it's leaking from.
Who installed the flywheel? That is where I would looking and asking questions.
Old Aug 26, 2009 | 03:46 PM
Guisslapp's Avatar
Automatic. Sorry, should have clarified earlier.
Old Aug 26, 2009 | 06:26 PM
Easy_E1's Avatar
Then you have a counter weight. Same thing as the flywheel in the seal area.
Who put the replacement engine in your car? They're the ones I would be asking about fixing it on their dime. But it could have happened at the Re-Man facility too. Could have been a defective seal.
All in all I think Mazda should fess up and fix it for free.
Old Aug 26, 2009 | 08:06 PM
invasion08's Avatar
You should be covered with a new engine comes a 1yr 12k mile warranty. I would call Mazda North America.
Old May 15, 2010 | 12:03 PM
Guisslapp's Avatar
Seems like the problem has come back. Looks like the oil is leaking from the same location as before, so I am taking it back to the dealership service department that did the last repair. Last time they replaced a counterweight. The paperwork said that the flywheel was wedged on the e-shaft. Wonder if it is the same thing again...
Old May 15, 2010 | 12:32 PM
zoom44's Avatar
yeah they keep f-ing up the replacment.
Old May 15, 2010 | 03:46 PM
Guisslapp's Avatar
Well, they were not able to diagnose the location of the leak, so they put some dye in the oil. Told me to drive another 500 miles and bring it back in. Oil was all the way around the oil pan, so it may be an oil pan seal. That is what I thought it was last time, so who knows?
Old May 15, 2010 | 04:58 PM
It could be a bad build from factory but ... my guess is the dealership who installed ur engine last time messed it up. Perhaps somebody overtighen something?
Old May 15, 2010 | 05:37 PM
laythor's Avatar
I zoom therefore I am.
you'd think the dealer would just send it to a better shop.. lol
Old May 16, 2010 | 08:05 AM
yiksing's Avatar
the giant tastetickles
Get them to fix it for free, use "4000 miles" as leverage
Warrior777
Jun 24, 2019 04:47 PM
WingleBeast
22
May 23, 2016 09:22 PM
TeslaMSI
Dec 10, 2015 01:10 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
