Kas
01-04-2004, 07:28 AM
Hey Guy's
Here is a list of standard vars that you may be looking for whilst working with OBD-II interfaces. I hope it helps.
Its taken for a bunch of .c code
static int reset_chip_proc(int msg, DIALOG *d, int c);
static int options_proc(int msg, DIALOG *d, int c);
static int page_flipper_proc(int msg, DIALOG *d, int c);
static int sensor_proc(int msg, DIALOG *d, int c);
static int toggle_proc(int msg, DIALOG *d, int c);
static int toggle_all_proc(int msg, DIALOG *d, int c);
static int status_proc(int msg, DIALOG *d, int c);
static int page_number_proc(int msg, DIALOG *d, int c);
static int inst_refresh_rate_proc(int msg, DIALOG *d, int c);
static int avg_refresh_rate_proc(int msg, DIALOG *d, int c);
static int page_updn_handler_proc(int msg, DIALOG *d, int c);
// Sensor formulae:
static void throttle_position_formula(int data, char *buf); // Page 1
static void engine_rpm_formula(int data, char *buf);
static void vehicle_speed_formula(int data, char *buf);
static void engine_load_formula(int data, char *buf);
static void timing_advance_formula(int data, char *buf);
static void intake_pressure_formula(int data, char *buf);
static void air_flow_rate_formula(int data, char *buf);
static void fuel_system1_status_formula(int data, char *buf);
static void fuel_system2_status_formula(int data, char *buf);
static void short_term_fuel_trim1_formula(int data, char *buf); // Page 2
static void long_term_fuel_trim1_formula(int data, char *buf);
static void short_term_fuel_trim2_formula(int data, char *buf);
static void long_term_fuel_trim2_formula(int data, char *buf);
static void intake_air_temp_formula(int data, char *buf);
static void coolant_temp_formula(int data, char *buf);
static void fuel_pressure_formula(int data, char *buf);
static void secondary_air_status_formula(int data, char *buf);
static void pto_status_formula(int data, char *buf);
static void o2_b1_s1_formula(int data, char *buf);
static void o2_b1_s2_formula(int data, char *buf);
static void o2_b1_s3_formula(int data, char *buf);
static void o2_b1_s4_formula(int data, char *buf);
static void o2_b2_s1_formula(int data, char *buf);
static void o2_b2_s2_formula(int data, char *buf);
static void o2_b2_s3_formula(int data, char *buf);
static void o2_b2_s4_formula(int data, char *buf);
static void obd_requirements_formula(int data, char *buf);
static int device_connected = FALSE;
static int reset_hardware = TRUE;
static int num_of_sensors = 0;
static int num_of_disabled_sensors = 0;
static int sensors_on_page = 0;
static int current_page = 0;
static float inst_refresh_rate = 0; // instantaneous refresh rate
static float avg_refresh_rate = 0; // average refresh rate
volatile int refresh_time; // time between sensor updates
static SENSOR sensors[] =
// Page 1
{ throttle_position_formula, "Absolute Throttle Position:", "", "0111", 1 },
{ engine_rpm_formula, "Engine RPM:", "", "010C", 1 },
{ vehicle_speed_formula, "Vehicle Speed:", "", "010D", 1 },
{ engine_load_formula, "Calculated Load Value:", "", "0104", 1 },
{ timing_advance_formula, "Timing Advance:", "", "010E", 1 },
{ intake_pressure_formula, "Intake Manifold Pressure:", "", "010B", 1 },
{ air_flow_rate_formula, "Air Flow Rate (MAF sensor):", "", "0110", 1 },
{ fuel_system1_status_formula, "Fuel System 1 Status:", "", "0103", 1 },
{ fuel_system2_status_formula, "Fuel System 2 Status:", "", "0103", 1 },
// Page 2
{ short_term_fuel_trim1_formula, "Short Term Fuel Trim (Bank 1):", "", "0106", 1 },
{ long_term_fuel_trim1_formula, "Long Term Fuel Trim (Bank 1):", "", "0107", 1 },
{ short_term_fuel_trim2_formula, "Short Term Fuel Trim (Bank 2):", "", "0108", 1 },
{ long_term_fuel_trim2_formula, "Long Term Fuel Trim (Bank 2):", "", "0109", 1 },
{ intake_air_temp_formula, "Intake Air Temperature:", "", "010F", 1 },
{ coolant_temp_formula, "Coolant Temperature:", "", "0105", 1 },
{ fuel_pressure_formula, "Fuel Pressure (gauge):", "", "010A", 1 },
{ secondary_air_status_formula, "Secondary air status:", "", "0112", 1 },
{ pto_status_formula, "Power Take-Off Status:", "", "011E", 1 },
// Page 3
{ o2_b1_s1_formula, "O2 Sensor 1, Bank 1:", "", "0114", 1 },
{ o2_b1_s2_formula, "O2 Sensor 2, Bank 1:", "", "0115", 1 },
{ o2_b1_s3_formula, "O2 Sensor 3, Bank 1:", "", "0116", 1 },
{ o2_b1_s4_formula, "O2 Sensor 4, Bank 1:", "", "0117", 1 },
{ o2_b2_s1_formula, "O2 Sensor 1, Bank 2:", "", "0118", 1 },
{ o2_b2_s2_formula, "O2 Sensor 2, Bank 2:", "", "0119", 1 },
{ o2_b2_s3_formula, "O2 Sensor 3, Bank 2:", "", "011A", 1 },
{ o2_b2_s4_formula, "O2 Sensor 4, Bank 2:", "", "011B", 1 },
{ obd_requirements_formula, "OBD conforms to:", "", "011C", 1 },
{ NULL, "", "", "", 0 }
DIALOG sensor_dialog[] =
/* (proc) (x) (y) (w) (h) (fg) (bg) (key) (flags) (d1) (d2) (dp) (dp2) (dp3) */
{ d_clear_proc, 0, 0, 0, 0, 0, C_WHITE, 0, 0, 0, 0, NULL, NULL, NULL },
{ page_updn_handler_proc, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, NULL, NULL },
{ d_shadow_box_proc, 40, 20, 560, 56, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ d_rtext_proc, 50, 25, 96, 20, C_BLACK, C_TRANSP, 0, 0, 0, 0, "Port Status:", NULL, NULL },
{ status_proc, 180, 25, 300, 20, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ reset_chip_proc, 490, 28, 100, 40, C_BLACK, C_GREEN, 'r', D_EXIT, 0, 0, "&Reset Chip", NULL, NULL },
{ d_rtext_proc, 50, 51, 96, 20, C_BLACK, C_TRANSP, 0, 0, 0, 0, "Refresh rate:", NULL, NULL },
{ inst_refresh_rate_proc, 160, 51, 175, 20, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ avg_refresh_rate_proc, 335, 51, 150, 20, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 87, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 91, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 0, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 94, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 123, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 127, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 1, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 130, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 1, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 159, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 163, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 2, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 166, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 2, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 195, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 199, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 3, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 202, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 3, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 231, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 235, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 4, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 238, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 4, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 267, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 271, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 5, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 274, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 5, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 303, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 307, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 6, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 310, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 6, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 339, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 343, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 7, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 346, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 7, 0, NULL, NULL, NULL },
{ d_box_proc, 40, 375, 560, 32, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ toggle_proc, 45, 379, 45, 24, C_BLACK, C_WHITE, 0, D_EXIT, 8, 0, NULL, NULL, NULL },
{ sensor_proc, 95, 382, 504, 24, C_BLACK, C_LIGHT_GRAY, 0, 0, 8, 0, NULL, NULL, NULL },
{ toggle_all_proc, 40, 420, 100, 40, C_BLACK, C_DARK_YELLOW, 'a', D_EXIT, 0, 0, "&All ON", NULL, NULL },
{ options_proc, 150, 420, 100, 40, C_BLACK, C_GREEN, 'o', D_EXIT, 0, 0, "&Options", NULL, NULL },
{ d_shadow_box_proc, 260, 420, 230, 40, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ d_button_proc, 500, 420, 100, 40, C_BLACK, C_DARK_YELLOW, 'm', D_EXIT, 0, 0, "&Main Menu", NULL, NULL },
{ d_ctext_proc, 300, 422, 38, 20, C_BLACK, C_TRANSP, 0, 0, 0, 0, "Page", NULL, NULL },
{ page_flipper_proc, 340, 425, 75, 30, C_BLACK, C_DARK_YELLOW, 'p', D_EXIT, -1, 0, "&Previous", NULL, NULL },
{ page_flipper_proc, 425, 425, 55, 30, C_BLACK, C_GREEN, 'x', D_EXIT, 1, 0, "Ne&xt", NULL, NULL },
{ page_number_proc, 300, 440, 36, 18, C_BLACK, C_LIGHT_GRAY, 0, 0, 0, 0, NULL, NULL, NULL },
{ NULL, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, NULL, NULL, NULL }
// Sensor formulae:
// Page 1
// Page 2
// Page 3
