View Full Version : Vibrations: bad engine mount symptoms?
JinDesu
07-21-2009, 09:58 PM
So I just got my car back from the shop after my accident about a month ago. I was driving it, and noticed these symptoms:
1) While the engine is in park, neutral, or idling in drive, there is an increase in vibrations. It's enough to make the glovebox rattle a lot.
2) While the engine is under load (normal driving), there is no increase in vibrations.
I saw that a lot of replies for engine vibrations are to change the coils, change the spark plugs. Can anyone give me the symptoms for those?
The reason why I believe it's the engine mount over the coils/ignition is because my car only has 1800 miles on it. Admittedly, it's an 06, and I do not know if coils/ignition degrade when unused. Also, the accident I had leads me to believe impact has caused damage to the engine mount. Does anyone have additional insight into this?
cyclone1208
07-21-2009, 10:25 PM
Its your engine mounts....get em change and yur back to new
JinDesu
07-21-2009, 10:27 PM
I'm bringing the car back to the shop tomorrow to do that. I wanted as much info as I could get on this issue so I can explain it to them. Thanks for your input.
Razz1
07-21-2009, 10:34 PM
Remember you have to drive the car a few cycles for the ECU to re-program itself.
What RPMs was that car idling at?
JinDesu
07-21-2009, 10:37 PM
Cold start 2krpms. After the engine was warmed, around 800-1000rpms. That hasn't changed from before the accident.
What is a few cycles? On off cycles?
Maaz
07-22-2009, 02:16 PM
its the engine mounts, you need new ones.
