View Full Version : What to do? Rear Lower Tie Rod bent
Efini 8 01-04-2004, 04:19 AM my rear lower tie rod is bent (one connecting the wheel hub to the mid section with a little screw with a dial on it) where to adjust caster I believe. Bent it drifting and I jumped a curb. Was doing a left hand turn then didnt countersteer in time then the oversteer was too great with the rear sliding out then hit the concrete curb with my rear right rim causing the lower tie rod to bent a little hitting the control arm.
Sputnik 01-04-2004, 10:51 AM You should take it to a dealership, have that tie rod replaced, have the rest checked to see if there was any other damage. It's hard to tell sometimes, and unless there is a weak piece in the suspension, more than one piece is normally damaged.
Then get a 4 wheel alignment again.
---jps
syntrix 01-04-2004, 02:04 PM Yeah, unfortunately it's usually more than one component that gets bent when you whack a curb.
Take it to a dealer or a good body shop (if they even have specs on hte car), and they can check frame, lower carriage, and each of the tie rods, etc.
Hopefully it's not that bad!
Efini 8 01-07-2004, 06:49 PM http://importupgrade.com/images/rx8/IMG_0066.jpg
Here is a pic of the bent rod
Gord96BRG 01-07-2004, 07:12 PM Is the control arm supposed to be curved slightly, or was that also bent?
Regards,
Gordon
Spin9k 01-07-2004, 09:24 PM Wow! Think of the lateral forces to do that kind of damage! To be able to bend two solid steel bars like that makes you wonder what those forces did to the frame and attachment areas? Yikes!
You might need a body shop frame straightener. :(
syntrix 01-07-2004, 10:02 PM They are both bent :(
You can see in this pic with my lower arm dropped:
http://www.swankmonkey.com/mig/albums/tein/IMGP1561.JPG
Efini 8 01-08-2004, 07:39 PM is that a pic of ur install when you did ur JIC coilovers Syntrix?
syntrix 01-08-2004, 08:28 PM Yes
Doctorr 01-12-2004, 10:32 PM Rim will be bent 'for sho'.
Spin it and watch it wobble.
Bearings will be damaged, need new ones, will last months but will eventually seize up. Please don't ask how I know,,,,
doc
Efini 8 01-20-2004, 07:01 AM fixed it... only took like 30 mins... now need alignment.
Efini 8 -
I fear I may have suffered the same fate - a bent rod and possibly the control arm as well. Can you share more details about what fixed it? Did you take it to the dealer or a body shop? Just what did you do? I don't have the tools nor the expertice to do this myself - but I want to understand the process.
project 05-20-2004, 12:51 PM Get your wheels checked out for cracks as well. I slid into a curb at about 15 mph in an unexpected snowstorm and broke both wheels on the drivers side. Luckily the only other damage was a bent wheel hub....
I will have them checked out. Thanks for the heads up!
RenesisX-8 05-25-2004, 02:12 AM I had to replace the same two arms on my eight.
The night I bought it, it was about 35 degrees and pouring rain. I got off at my exit and it was not raining and looked dry. I went around my usual fun corner a little conservatively and as soon as I throttled out the car snapped and I locked them down but it went past 90 degrees and crossed the road sliding onto the curb RR first.
I replaced the rods myself, dealer ($112) ordered them the next day (Fri.) and I fixed it on Monday, before the wife found out hehe.
After that the car performed flawlessly. I pushed the car hard on every curvey road and in the mountains.
darkducati 05-25-2004, 09:28 AM This sounds like an excuse for a call to JIC. :D
jaybraveheart 05-25-2004, 10:16 AM I did te same thing but my airbag deployed as well:(
I had to go to the dealer It's been two weeks and they still haven'y gotten parts:(
roto8car 11-16-2007, 04:19 PM I just did the same thing. car-part.com has the parts listed for $45. A place in OH will ship a rod for $15 extra and it'll be here in 3 days. Tires plus quoted me 260 for the whole job and an alignment. How hard was it to swap the bushings?
BigRed 11-16-2007, 05:05 PM good use of the search button^, but its 3 years old:)
roto8car 12-04-2007, 12:03 PM figured i should add any info for future dummies:lol:
G3tR3DDY2GR3DDY 12-04-2007, 12:46 PM i ususally have quite a few of these laying around from parts cars too if anyone ever needs one pm me
